Cold>Edge
Old Feb 1, 2011 | 06:06 PM
sylentbutvylent's Avatar
Cold>Edge
Has anyone had a problem with your Edge in cold weather?
Old Feb 1, 2011 | 09:39 PM
Meatwagon's Avatar
Describe "problem". Mine has an issue when starting up - screen locks and freezes until it warms up.
In mid December, it reset the unit back to stock even though my truck was still on Level 2. I found that out the hard way.
Old Feb 2, 2011 | 12:13 AM
Extreme temps of both cold and hot seem to disrupt the display of the edge evolution screen.....
I have not seen or read about any issues with the CS or CTS yet as far as their displays go....
Old Feb 2, 2011 | 09:55 AM
BigTerp's Avatar
My CS on occasion will not start up when I start my truck. Once I turn my truck off and then back on everything works fine. Never tried to just run my truck and see if it starts itself back up. This has happened maybe 3 times since I got the unit (mid Jan.). But only seemed to happen when the temperature was below 20 degrees and my truck had sat all night. Other than that, absolutely zero issues with my CS.
Old Feb 2, 2011 | 10:02 AM
My screen was blank this morning, didn't like the 14*. After the truck warmed up, I unplugged it, plugged it back up and it was fine.
Old Feb 2, 2011 | 10:33 AM
sanndnsurf's Avatar
Ha its brutal down here
Old Feb 3, 2011 | 09:46 AM
Longshot270's Avatar
Mine is a monochrome and it changes really slowly in the cold. Instead of showing numbers, the spaces like RPM turn into a blur because the screen cannot physically update fast enough.
Old Feb 3, 2011 | 10:21 AM
LonestarROB's Avatar
No kidding!! I'm not even going out to check my CS.
Old Feb 3, 2011 | 11:59 AM
rllackey28's Avatar
My only problem with my Gryphon is that it is bad to kill the battery in cold weather.
Old Feb 3, 2011 | 11:32 PM
When you park the truck for long periods just unplug it....
Also
You may want to invest in a new battery too....
Also
Battery tenders work wonders....
Also
Another way is someone on here bought a solar power battery tender....
Old Feb 4, 2011 | 05:20 PM
rllackey28's Avatar
Also
Also
Also
It's not long periods. I can run it on Sunday and if it is in the teens weather wise it would bed dead on Monday. Warmer than freezing and no problem. So I've been unplugging pretty much whenever I am finished driving for the day. I know I need a new battery. Trying to figure out the best bang for my buck. Will look into a battery tender. Thanks.
Old Feb 5, 2011 | 01:43 AM
The Real Mccloy's Avatar
Hi,
I have never had any problems with my Evo operational wise, of course the LCD is slow to update like last week when the temp was showing -31F when I left for work.
Old Feb 5, 2011 | 02:09 AM
Raptor05121's Avatar
every LCD ive ever used is really slow when its cold
Old Feb 8, 2011 | 08:21 AM
RetiredNavy02's Avatar
I just got the Edge Evo for my 2005 F150 yesterday (birthday present from wife). My truck is completely stock (may do a DMV mod however). Reason I wanted the Evo is to aid when towing our 27' travel trailer. Anyways, the New England weather has been pretty brutal this year (lots of temps single digit and below). I had asked Mark Hayward from Edge Products what to do with the programmer and temps dropped in the teens and his feedback was to plug unit and bring indoors.
As a noobie, when I hook the programmer back up do I need to reprogram the level?
Thanks!
Old Feb 8, 2011 | 09:52 AM
Thanks!
Nope...
