Edge Causing my truck to cut out on Lvl 3?
Old Jan 26, 2011 | 12:33 PM
HessFx4's Avatar
I have my edge set on level 3 with a couple things changed like Wot shifting, not sure what else atm, but anyway anywhere from 1150-1450 rpm 45-55 mph it cuts out sometimes..? well I took it back to stock and it doesnt cut out at all, returned it to lvl 3 with leaving it how it comes, and it still does it, I was thinking it was something that I did, but it's not. Now i'm running lvl 1 and it runs great. But I would like lvl 3 to work, any ideas on something I could change?
Old Jan 26, 2011 | 12:35 PM
What are you shift points and what is your max rpms set at?
Old Jan 26, 2011 | 12:37 PM
Also, how long since fuel filter was changed?
Old Jan 26, 2011 | 01:08 PM
HessFx4's Avatar
I think my shift out is 5200.. Whatever edge uses, and i bought this truck Oct. 26 and it right at 80k and now had around 83k so I really have no idea when or how many miles the fuel filter has in it..
Old Jan 26, 2011 | 01:13 PM
JackandJanet's Avatar
Any codes when your truck "cuts out"? And, what exactly do you mean when you say the truck "cuts out"? Does the engine quit running?
Are you possibly trying to run Level 3 using 87 octane gas?
- Jack
Old Jan 26, 2011 | 01:15 PM
Besides the fuel filter consider cleaning the TB and MAF.....
Threads on how to do this are found in the " how to" section of the forum......
If this doesn't help contact edge....
Old Jan 26, 2011 | 02:27 PM
HessFx4's Avatar
By cutting out I mean, it feels like it's not getting enough fuel or it's missing, give it a little gas and it's fine, just through those rpm and mph which is most if my driving.
Old Jan 26, 2011 | 02:28 PM
HessFx4's Avatar
And no it does't throw any codes and I use 93 octane regardless if what level im running
Old Jan 26, 2011 | 02:34 PM
On a dirty MAF or TB sometimes you won't get codes. If they are really, really dirty then you'll get them or your truck will go into fsm.
80k is about time for spark plugs also.
Old Jan 26, 2011 | 02:47 PM
HessFx4's Avatar
yea I was just reading up on the Spark plug threads.. I dont know if im brave enough to tackle it... but I really want to well see.
Old Jan 26, 2011 | 04:22 PM
Veteran: Army
how old are the plugs and COPS??
Old Jan 26, 2011 | 04:49 PM
HessFx4's Avatar
no idea, I bought the truck with 80k miles at the end of Oct. and now has 83K. but it only does it on level 3.
Old Jan 26, 2011 | 06:15 PM
jerzpilot's Avatar
Clean the maf and the tb, change the fuel filter if it hasn't been changed in the last 20k miles and if is still doesn't fix it than it might be the f/a ratio. more air than fuel entering the chambers. good luck.
