Edge help??
Old Dec 31, 2010 | 09:35 PM
skizriz's Avatar
Edge help??
Having a problem with my Evo,and hoping somebody can give me some advice. It's a 2001 with a 5.4.
Whenever I change any of the custom settings on level 2 or 3, the truck will run very rich, barely idles,wants to stall,black smoke at idle,smell of raw gas. Also threw a code "TP sensor inconsistent with MAF sensor (?)".
Runs like a scalded dog with the settings when you pour the coals to it.
Just about all of the changes I made were to the rev limit and shift points. Also gear ratio and tire size.
I left the spark and WOT fuel alone.
I am running 93 octane.
Have the Gotts mod,K&N filter, and 3"in 2.5"DO high flow muffler.
Truck runs smooth as silk on all canned tunes with no custom settings.
Cleaned the MAF sensor about a month ago, and replaced fuel filter.
Tire size 2565 mm
Gear ratio 3.55
Timing 0.0
WOT shift 5000,5000,4800
Shift firmness 12,12,9
Max RPM 5,400
WOT fuel 1.2
Any ideas???
I also checked for a update when I bought it. It said none were available.
Old Jan 1, 2011 | 06:21 PM
skizriz's Avatar
No one?? I read about 2,347 posts, came up with this exact problem 3 times. The posts ended with no solution though.
Should I try an update now that it has been installed in the truck?
Just hoping for an easy solution before calling customer service.
