P1602 touble code on edge
Old Dec 12, 2010 | 05:20 PM
bhtyler10's Avatar
My edge cs is showing the trouble code p1602 when i read dtc's. I researched and found it means Immobilizer module-(PCM) communication fault. What do I need to do about this? Is it something to worry about?
My truck runs fine, only thing is my speed on my edge wont calibrate, but it hasnt since I got it. would this code have anything to do with it?
Old Dec 13, 2010 | 10:30 AM
Call edge tech support.......they need to know about this.
Old Mar 1, 2011 | 11:32 AM
jake605ktm's Avatar
i have the same thing that is coming up on mine and i just installed it less than 40 min ago...im about to send the damn thing back. its giving me that and a p1000 error. did edge tech support get the problem fixed for you?
Old Mar 1, 2011 | 12:55 PM
The p1000 is a pcm relearn code and it can only be cleared by driving the truck....
This code happens when the truck is put back to stock....
Old Dec 29, 2011 | 08:12 PM
mx52's Avatar
Did you ever get an answer on the code being thrown? I have the same thing.
Old Jan 2, 2012 | 08:17 AM
jake605ktm's Avatar
Run the update on it and you should be fine. I had the code for a week before I ran the update and it's been since march and I haven't seen it since
