Tired of Edge Problem, any help?
Old Dec 7, 2010 | 05:57 PM
bhtyler10's Avatar
I have had my edge evo cs for about a month and a half now. I love the performance of the towing tune, and the gauges are sweet. However, I am tired of not having my speedometer calibrated. And yes I know that the edge unit will read a little off of the ford speedometer, both are off. when going 75 via gps speed, my edge reads 68 mph. It is about as far off as it was before I got the edge. I have programmed and reprogrammed tons of times, changing the tire size, but it is always off. I called edge, and they walked me through the steps, still off. Then they had me plug my unit in to Fusion, and they took files off of it to look at, and then later called and took even more off. Their verdict was that the engineers told them the Revolutions per mile were changing with the programming of 35's, and nothing was wrong. There is definately something wrong, anyone know what the problem could be? Any help at all will be appreciated.
Old Dec 7, 2010 | 05:59 PM
That is a new one!
get a gps and adjust the Edge numbers until it matches the gps at 60 mph.
Old Dec 7, 2010 | 06:03 PM
shotgunz's Avatar
Is the gear ratio correct?
What is the tire ratio? If the tire is really 35" (diameter), I would try 3% squish (35 x .97 = 33.95 diameter/height) and then adjust from there.
bhtyler10's Avatar
That is a new one!
I have a gps, and no matter what I do to the tire size numbers, the speed readout it the same amount off
Old Dec 7, 2010 | 06:10 PM
There's two different ways to change the tire size.....
Are you using the custom option way?
Or
The on screen through a menu option way?
Old Dec 7, 2010 | 06:12 PM
bhtyler10's Avatar
Or
I have been using the custom option way. However, when I first got it I think I used the on screen menu way
Old Dec 7, 2010 | 06:39 PM
You might want to check your tire size in the on screen menu way.....
Old Dec 7, 2010 | 07:39 PM
JackandJanet's Avatar
What size tires and gears do you have in your truck? Please let me know these values and I MAY be able to help. (My speed reading and odometer readings are correct, but I can't simply use the Tire Size in the "Options" menu. I have to adjust it in the "Custom Options" menu.)
- Jack
Old Dec 7, 2010 | 08:28 PM
bhtyler10's Avatar
- Jack
i have 295/65/r20 trail grapplers. Actual height is 35.47x12.13 according to nittos sight
EDIT: I have 3:73 gears
Old Dec 8, 2010 | 06:29 AM
shotgunz's Avatar
Unloaded (no squish) diameter/height: 35.098"
3% squish diameter/height: 34.05"
4% squish diameter/height: 33.69"
5% squish diameter/height: 33.34"
Unloaded (no squish) circumference: 2800.7mm
3% squish circumference: 2717
4% squish circumference: 2689
5% squish circumference: 2661
Again, I would start with 3% squish and adjust using a GPS or known distance (10 or more miles; see the formula below).
Obviously it's critical that the GR be correct in the custom options.
Old Dec 8, 2010 | 09:37 AM
Revs/mile=575
Old Dec 8, 2010 | 11:10 AM
OK, everyone is here ahead of me (shows what happens if you decide you need to sleep).
In your original post, you said the Edge reads 68 when the GPS shows 75. We'll assume the GPS is correct (but it WILL have some "lag", and the Edge won't). Speed readings are best made on a straight, level stretch of highway with the cruise control set and over about a 10 second interval.
Anyway, your PCM thinks your tires are smaller than they really are if your Edge (the PCM) reads low and your Gear Ratio (GR) is set properly. So, please verify that you really do have a 3.73 GR set in the "Custom Options" menu (as shotgunz advised).
Now, I don't have any faith at all in the Tire Size (TS) value that is set in the "Options" menu, so even though my tire specs are entered there, I always make sure an "adjusted" diameter is set in the "Custom Options" menu. Here, on the CS/CTS platform, I've found it's easiest to use inches, and you can enter a value that is correct to the nearest tenth of an inch.
When I check Nitto's chart, it tells me 585 revs/mile for your tires and that corresponds to a "loaded" diameter of 34.5". That's what I'd start with. Then if the Edge still reads too slow, increase the value. If too fast, decrease the value. Remember, the PCM must be reprogrammed with this new value, or it will have no effect.
If you need to correct, you can use shotgunz' formula too, substituting speeds for odometer readings, i.e.:
(GPS speed/Edge Speed) x Old Tire Diameter = New Tire Diameter
Let us know what happens, please.
- Jack
Old Dec 8, 2010 | 05:50 PM
bhtyler10's Avatar
- Jack
So I made sure both options and custom were 34.5 and still off by the same amount of speed
Old Dec 8, 2010 | 06:53 PM
onewheelneil's Avatar
Im having the same problem but the kicker is my tires/gr are stock........my speedometer is reading 75 and the cs is reading 68,with my wife right next to me in her bone stock 08 tahoe she said we were running 70? Any ideas for me? Highjacking not intended,by the way!
Old Dec 12, 2010 | 03:36 AM
bhtyler10's Avatar
okay, hopefully this will help someone who is good at this stuff. So i went to the read trouble codes function on my edge cs and I have p1602 which i looked up and it means -Immobilizer module-(PCM) communication fault. would this have anything to do with my tire size not changing my speed?
