Need help with conversion
Old Dec 5, 2010 | 09:09 PM
townsr's Avatar
I have a 2000 F150 and switched out the motor with a wrecked 2002Lightning. I have swapped wiring from front to rear. The 2000 model does not have a chip and I do not have the key for the 2002 model. The truck will not start now and the theft light blinks rapidly. Any advice on how to bypass this?
Old Dec 5, 2010 | 09:11 PM
blackedoutV6's Avatar
Buy a tuner and have the PATS system turned off.
Old Dec 5, 2010 | 09:15 PM
townsr's Avatar
Should the tuner be available at a standard auto parts store?
Old Dec 6, 2010 | 01:24 AM
Probably, but you don't want to go there. Start reading threads in our Tuners forum - especially the sticky threads.
Old Dec 6, 2010 | 03:34 PM
Veteran: Army
x2 on needing a custom tune along with the hope that you at least changed the rods
Old Dec 6, 2010 | 07:52 PM
JackandJanet's Avatar
Townsr - since the majority of the replies suggested a "programmer" fix, I moved your thread here. Please don't start another thread on the same subject in a different forum, it wastes people's time and can give you confusing results. I removed the thread you started here.
Thanks - trying to help!
- Jack
Old Dec 6, 2010 | 11:25 PM
You might want to start by reading this link.....https://www.f150online.com/forums/ar...pats-info.html
If that doesn't help start to contact some of the tuners in my Sig for support.
