04 f150 5.4 triton tuner that can adjust idle?
anyone know which tuner I can get for my 2004 f150 5.4 triton that can adjust the idle up a little?
I have a rough idle, it's a little too low, any higher and there's no more roughness, it's just always been this way, but no warranty so I might as well get a tune now
SCT and Gryphon/Edge with custom tunes can both adjust the idle.
But, I would attack the cause of the rough idle vs. masking it.
What is the idle at now?
Any DTCs?
Regular maintenance? Plugs? Cops? Air filter? Fuel filter? MAF clean? Throttle body clean?
Any DTCs?
Rough Idle.....depending on the DTS's....reminds me of my problem. Engine could have jumped time by one or more teeth. Try pulling off the cam position sensors. This will put the motor in safe mode. If the rough idle goes away, then you may be on your way to solving your delima. It seems as though the 04's are getting more popularity for jumping time. I agree that you should not try to mask the rough idle problem. Post the DTC's.
