Custom or Canned - what it really means on a F150
Having read many threads on tuning, including the "sticky" ones, I was still not sure what a "custom tune" on a stock truck really meant. I had a good discussion with Bill at PHP and wanted to share what I found out:
1. Custom really means that the particular tune that the truck came with is used as a basis for the custom tune.
2. The "Hex" code isn't a code at all. It is a file name for the configuration file that came with the truck.
3. The position of the digits in the "hex code" are significant. Looking at my Hex code of "RXFM4R2," the first four characters "RXFM" simply mean that it is for a 2009 F150 4x4 and any other major configuration for my truck (such as transmission type). The next character "4" means that this is major version "4," which varies by region that the truck was sold (cold/hot climate, altitude taken into consideration). The last two characters "R2" is the minor version - this changes for ANY change to the program and is not necessarily sequential (sometimes numbers are skipped).
So, when you get a canned tune, you are getting one that does not consider the region where the truck was sold or any major differences between F150s. The tune is the same for 2x4, 4x4, max trailer tow, etc., while both the stock tune and a custom tune take these variables into consideration. That is why a custom tune can perform better.
Also, if you get pinging (stock or tuned), the computer backs the timing way back and doesn't forget this for a long time. It can be reset by removing the battery cable for a little while.
I hope this is helpful.
"Goof" info??? I hope it is correct!
The only thing I was a little fuzzy on is whether the major version number or first four characters change for the region-specific settings.
While I am at it, another thing that Bill said is that the shift firmness on the '09 - '10 is primarily controlled by the ECM. The TCM allows the shift points to be moved.
The only thing I was a little fuzzy on is whether the major version number or first four characters change for the region-specific settings.While I am at it, another thing that Bill said is that the shift firmness on the '09 - '10 is primarily controlled by the ECM. The TCM allows the shift points to be moved.
Good info:
One very important consideration when buying a performance product and comparing horsepower numbers is altitude.
What altitude is the test dyno?
What altitude is the consumers vehicle?
I found this out years ago when EDGE first came out with the tuner for the 04 Ford F150. While I liked the increase in performance, and the better shift commands, it really did not impress me at first. Then I happened to take a trip to an area over 4000 feet. It was like I had a different truck. My wife even said the truck sounds different. Wasn't sure what the difference was at first. Even had "sea level" fuel in it at the time. I was able to duplicate this several times before I sold the truck.
The only explanation I could come up with was that EDGE products is based out of Ogden Utah and is over 4000 feet. So the tuner is tested at that altitude.
So I will not buy a canned tune next time. It will be one that I can data log and get the best tune for sea level running in the hottest time of the year.
For those of us old enough to remember, "tuning" meant changing jets for the carb, adjusting the timing, and maybe putting in a set of colder plugs. Now we expect the computer to do it for us. I used to double stack 14 inch air cleaners on my Bronco. If it pinged, I put a bigger jet in the holley, or backed off the timing.
So when you are looking for aftermarket performance, you must consider everything before you buy. When I look at a dyno sheet and see that I can only expect a horsepower gain at 4200 rpm, move along. Would be a waste of money for me. If it shows an increase in torque at 1500 rpm, I would jump on that.
The guy that goes WOT from red light to red light may appreciate a performance mod much more so than the guy that drives with the egg on the throttle trying to save fuel.
That's why I sometimes put in a higher octane fuel when I am towing in the hottest time of year, or going up a pretty steep grade. It keeps the computer from backing off the timing, thus reducing power. It's also why I think some guys will rave about how well an intake or exhaust works, where as another says it did not help at all. It all has to do with altitude, humidity, and driving style.
The bottom line is that the consumer must do homework and pay attention to detail. Consider your driving style and needs vs what you read on these websites.
Thanks, 2009KR and expy03 - I liked your posts so much I copied them to the "Questions About Tunes" thread.
I appreciate your efforts to make the information about tunes more understandable and complete.
- Jack
- Jack
Yes......and........along with that you may also get an updated one that'll correct problems others in the series were having.......
Good info:
But
Why does edge incorporate beta testers into the mix?
Yes the origination of the canned tune was on the dyno but was revised through many inputs of the beta testers and continued reviews of the engineers.
There are other factors that contributed to your trucks behavior when it was driven at a higher altitude.
At a specific octane for which yer engine is tuned - adding octane to alleviate - or 'prevent' the possibility of - detonation or pinging, is a bandaid - and it's really just masking an underlying issue. Bottom line - if it's tuned correctly, for that octane in question - you should not be pinging. The vehicle's closed & open loop control coupled with all accurately reporting sensor inputs, are fully capable of doing this, without adding any octane 'padding', regardless of environmental conditions.
Underlying issues usually connotes a vehicle maintenace issue - or a component degradation/failure, if it's not poor quality gas, or issues within the aftermarket calibration itself.
(BTW - the concept of - and obvious benefits derived from - full 7-digit strategy-matched custom tuning have been discussed here for almost 10 years, even before the advent of handheld flash devices (chips inserted into J3 ports) ... just fyi)
Q = Running higher octane on a lower octane tune.
A =
To answer your question just for future reference - what happens is you lose power, but it does not actually hurt anything to run higher octane on a lower octane tune.
For example, let's say yo have an 87 octane tune loaded up and you have 91 octane in the tank - or 93 octane. Well, what happens is that you just don't'; make as much power, as the engine is not actually tuned for that higher octane - so the peak cylinder pressure does not occur when it should. What normally happens in a case like that is that on the bottom end, it makes god power, but then the power peaks early, like about 4000 rpm or so, and then from there on up it does not make any *additional* power even though you may take it all the way to say, 5200 rpm just for example - again, it's due to the fact that the engine is not actually *tuned* for that much octane - so you are using too much octane for the tune. That will NOT hurt the engine, it just means you don't' make as good power and the fuel mileage usually is not as good, either.
Now if you did the opposite, and ran 87 octane on a 91 or 93 octane tune, then you would usually get pinging, or what is called spark knock - and that *is* bad for the engine if it is prolonged & sustained, so that is a very bad thing to do to an engine - meaning running too LITTLE octane for the tune.
But what you did, running too MUCH octane for the tune, will not actually hurt the motor - it's just a waste of money, and you will not make as much power as if you simply ran 87 octane on the 87 octane tune.
By the way - when we dyno a vehicle, we typically dyno it on it's higher performance tune, simply because most people come here (or get datalogged at their local dyno) with premium gas in the tank - then we make the corrections, if any are actually needed, to dial in the A/F ratios. It's called calibrating the mass airflow sensor's transfer function.
Now once that is done on ONE tune, then that same calibration is put into your other tunes, as that same calibration for that sensor will not change whether you are running you 87 octane tune or your 93 octane tune, etc.
I hope that sheds some more light on this for you, & glad you are enjoying our Troyer Performance tuning!!
I'm not disagreeing with you on the altitude point......
But
But
If the knock sensor detects pinging what does the ecm do?
What are some causes of pinging or "detonation"?
Are all tanks of fuel the exact octane?
If a vehicle is tuned for an altitude of 5000 feet, and is driven in the hot dessert in the heat of the summer with temps over 115 degrees, can the ecm adjust the timing and fuel management enough to maintain the same horsepower under those conditions?
I also understand that under ideal conditions that is it a waste of money to add a higher octane. But my objective is to not lose power under extreme conditions. By adding a higher octane, my hope is to prevent the ecm from retarding the timing and cutting power. If you have never driven at temps of of over 110 degrees and felt the lack of power I understand it's hard to imagine how much of a power lose is felt.
What normally happens in a case like that is that on the bottom end, it makes good power, but then the power peaks early, like about 4000 rpm or so, and then from there on up it does not make any *additional* power even though you may take it all the way to say, 5200 rpm just for example - again, it's due to the fact that the engine is not actually *tuned* for that much octane - so you are using too much octane for the tune.
(BTW - the concept of - and obvious benefits derived from - full 7-digit strategy-matched custom tuning have been discussed here for almost 10 years ... just fyi)
