Edge/PHP gas question
Old Aug 19, 2010 | 04:38 PM
sbchris's Avatar
Guys, if I am running a 93 octane tune and the only gas around town is 91 do I back the timing off to -1?
Lets say I am in the mountains and only 87 is around, would that be -3 from a 93 tune?
Old Aug 19, 2010 | 05:08 PM
shotgunz's Avatar
From page 17 of the Gryphon manual:
Lowering this value will not harm the engine but may reduce performance and economy. A good general rule is to increase timing 0.5 degrees for every octane count you go up. For example, if you are running 93 octane fuel in level three, you could safely increase the timing 1.0 degrees.
On the surface, you are correct. However, if you detect pinging, the ECM will retard the timing and your performance (and MPG) will really suffer.
Most of the time you are better off increasing 1/2 degree at a time until you detect pinging. Then decrease 1/2 degree.
So in your 91/93 scenario, if you're not detecting any pinging, you should be fine. If you are, try decreasing 1/2 degree. If you're still pinging, decrease another 1/2. You may even have to go to 1-1/2 degree.
Personally, I wouldn't run 93 performance on 87.
Old Aug 19, 2010 | 05:16 PM
sbchris's Avatar
How audible of a ping are we talking about? I thought the motor has knock sensors on it that will pick it up before our ear can even hear it if I am correct? I know my 98 cobra had this situation when it was boosted.
Old Aug 19, 2010 | 05:29 PM
The knock sensors can help you within a small range. I believe you are safe at high altitudes (5000+) on mountain gas that's 2 points lower. I'm running stock and have never heard a ping on 85 up there, and it gets excellent gas mileage. I would not run a 93 tune in California, period - get a good 91 tune and have an 87 tune available.
If you hear ANY ping, back it off.
Old Aug 19, 2010 | 05:37 PM
shotgunz's Avatar
I've never had a pre-detonation issue on my trucks (well, I did on my 91 Ranger), so I'm not sure how long it takes the ECM to retard the timing after pre-detonation is detected.
It's my understanding that the engine can still ping for a brief period until the knock sensors retard the timing. You could use the spark advance/retard PID to monitor the timing.
Old Aug 19, 2010 | 05:54 PM
Ping = put some marbles in a tin can and shake.
Old Aug 19, 2010 | 06:47 PM
I am assuming you are running a 93 custom tune. Yes, back the timing off 1.0 to run 91 octane. If it is the canned level 3, it was written for 91 octane.
Old Aug 19, 2010 | 07:10 PM
There aren't too many states left where you can get 93 octane anyway. 91 and 92 is becoming more and more common, and in the mountains you are going to get 89 to 91 at best for a full premium. You will also find stations that don't even have a full "premium" any more, just regular and midgrade (89).
Old Aug 19, 2010 | 07:42 PM
sbchris's Avatar
Thanks guys exactly what I was looking for!
