Thinking of buying used Edge Evo cheap...
Old Aug 2, 2010 | 05:00 PM
Originally Posted by MGDfan
Yes, really; one of several dealing with this and the 'shade-tree' intake mods. ==> https://www.f150online.com/forums/2230502-post10.html
You takes yer chances , or not. Direct A/F Measurement is key.
I don't take chances, which is why I invested in the means to do direct measurements.
MGD
After reading that I'm wondering if Mike wasn't actually making reference to the already known lean conditions that can be found in the 04-05 5.4 3v?
Sounds also like the fist versions of the MIT were the most problem causing ones.
Old Aug 3, 2010 | 09:44 AM
Mr. eXtreme's Avatar
So since mine is a late 06 built truck am I in the clear??
Also if I use only the trans only setting till I can change stuff or get custom tunes... That shouldn't hurt anything right?
Old Aug 3, 2010 | 09:53 AM
Get it, you will be fine. Just keep in mind that the Edge tunes are written for the stock intake, so if your intake flows more air, the tune will not take any more advantage of the extra air over your stock tune.
Also, I would not worry about using level 2 or level 3 with your 06. If it pings, then I would be concerned, but that is highly unlikely. Possible, but unlikely. I would, just as soon as possible convert to the Gryphon, though. The custom tunes are much better and can be written to take advantage of the intake.
Old Aug 4, 2010 | 04:36 PM
Awesome! Thanks. It will be here Friday!!
Once I have it I'll check for updates. Then install and play for a bit.
In a few months when more $ is around to spend upgrade it to the Gryphon!
Old Aug 6, 2010 | 12:24 PM
it's here!!! It's here!!!
Everything seems to work as it should!!
