Edge Ruining Injectors
He's probably referring to the bad injector fiasco that the 05's had to endure, and he probably thinks that adding a programmer will exasperate the problem. In reality, there has been no cases of a programmer causing bad injectors to go worse. There is no correlation between an Edge and bad injectors.
I'll note this and add it to the transmission failures also.
NOT!
