New CS Question
Old May 13, 2010 | 06:46 PM
FX4Nick's Avatar
New CS Question
The setup and install is the same for the CS as the original Gryphon right? I'm talking about the initial OBDII plugin procedure.
Old May 13, 2010 | 08:25 PM
JackandJanet's Avatar
Almost. The CS/CTS doesn't seem to want you to have the ignition ON when plugging it in. (It may not matter). But, with the key OFF, the unit comes alive and then prompts you to turn the key ON. I would do it that way.
I say this because SOME programmers tell you to plug them in with the key OFF. Edge doesn't say, but they imply that the key is OFF and it actually makes more sense to do it that way.
- Jack
Old May 13, 2010 | 08:48 PM
FX4Nick's Avatar
Makes sense to me, but just wanted to check
