2 questions about an edge?
Old May 7, 2010 | 10:36 AM
JimmysotherFORD's Avatar
i have a 97-03 edge, and just bought a 01 mustang GT, (yes i know an edge won't tune it) can i use the edge to pull the pcm code off the mustang? i really want some tunes for it. thanks.
Old May 7, 2010 | 10:59 AM
Veteran: Army
yes, you should be able to pull the ecm strategy code out of it
Old May 7, 2010 | 11:45 AM
i figured it might be possible, and forgot the second question. can i clear a CEL on the mustang with the edge?
Old May 7, 2010 | 12:15 PM
I have my doubts that it will read the strategy. That strategy has to be in the device for it to recognize it, was my understanding, and it will only have strategies for trucks. At least that is how I understood it worked.
Old May 7, 2010 | 12:20 PM
JackandJanet's Avatar
I thought the same thing Jim - but, it certainly won't hurt to try. Jimmy, it would be great if you could report back to us on this.
- Jack
Old Nov 21, 2010 | 02:13 PM
UPDATE
got around to doing this and it not only pulled the HEX code but also (as i suspected) the gauges work also.
Old Nov 21, 2010 | 02:21 PM
Stu486's Avatar
so..this means i can hook my gryphon up to my e250 work van with the 5.4 2v and check codes? my truck is a 5.4 3v. have been curious if that would work but never got around to asking....kinda scared to lose any custom tunes if that would even happen........
Old Nov 21, 2010 | 02:24 PM
as long as you don't program it you can't loose the tunes. checking the codes should work on any ford vehicle with OBD II it's a generic function.
Old Nov 21, 2010 | 02:27 PM
Stu486's Avatar
thats what i thought....ill try her out later and see how it goes.
Old Nov 22, 2010 | 11:06 AM
I would just suggest to put the original vehicle back to stock before checking another vehicle......I hate seeing Help! threads......
Just a thought.......
