gray, black colored smoke?
Old Apr 22, 2010 | 11:48 PM
bankrpt's Avatar
I have a question when I get on my truck really hard some gray, black colored smoke blows out the tailpipe. I know its not burning oil cause it would be white smoke and my truck never uses oil, I have heard that gray, black smoke is unused fuel that wasn't burnt up. My truck has a sct tuner, banks exhaust, jlt intake, rear cats deleted, efans. I'm wanting to make sure its nothing that will hurt the truck thanks for any input.
Old Apr 22, 2010 | 11:51 PM
dilloncawthon's Avatar
i was going to say the intake is probably making it run lean but you said its black smoke.
Old Apr 23, 2010 | 01:17 AM
timmypstyle's Avatar
i know that the black smoke on a diesel is unburned fuel, but a gas engine i am not sure. when i had my 96 trans am apparently i had black smoke like you. someone told me it was burnt piston rings, but i think he was mistaken. hopefully someone will chime in with some info.
Old Apr 23, 2010 | 01:25 AM
bankrpt's Avatar
Burnt piston would be white smoke cause its burning oil, I have seen a few vettes, and other performance cars and trucks blow black, gray smoke when they get on it, I also have a 05 Ford f350 with the diesel and its turned up and it blows black smoke too.
Old Apr 23, 2010 | 02:05 AM
i thought white with a sweet smell was coolant burning and blueish white was oil. i KNOW for a fact that diesels will put out black smoke as unburned fuel. but like i said gas engines i dont know. just know that someone told me my trans am did it when i got on it. and it wasnt beat on before i got it. and yes i put it thru its paces but nothing a vette engine cant handle
Old Apr 23, 2010 | 06:29 AM
bankrpt's Avatar
Yeah blueish white is what I meant its probably nothing but my fuel is set to high on my programmer @ WOT but i was just wondering
Old Apr 23, 2010 | 12:41 PM
JackandJanet's Avatar
"Blueish" is oil, and it doesn't take much at all to get smoke when you burn oil.
Grey to black is a rich running engine. I suspect that is what you have.
White smoke (vapor) is engine coolant.
- Jack
Old Apr 23, 2010 | 10:15 PM
bankrpt's Avatar
OYeah that's what I thought it was rich. I need to get a custom tune and probably change my plugs. I have 85,000 miles on the stock ones.
Old Apr 24, 2010 | 04:52 AM
openclasspro#11's Avatar
for the love of Jesus, u r running an 04 with that jlt intake w/o custom tunes?
Old Apr 24, 2010 | 06:09 AM
bankrpt's Avatar
No I am running the tune that came with the sct tuner and intake when I bought it I'm talking about like a mail order tune from vmp, troyer, PHP, etc.
Old Apr 24, 2010 | 06:16 AM
sonic69's Avatar
You need a custom tune on an 04 to make up fpr the intake. I'm shocked that you aren't throwing any codes.
Old Apr 24, 2010 | 07:32 AM
bankrpt's Avatar
LOL when you buy the jlt intake and sct tuner from jlt the programmer already has a tune for the intake, you go under intakes in the tuner and you select jlt intake and there's my tune for it.
Old Apr 25, 2010 | 08:22 PM
batn68's Avatar
I puff out black smoke as well and I am tuned, it did it before when it was all stock as well.
Old Apr 25, 2010 | 08:35 PM
bankrpt's Avatar
OK I just wanted to make sure it wasn't nothing bad
Old Apr 25, 2010 | 11:55 PM
Oxlander's Avatar
nothing to bad. With black smoke, your truck is running rich. (blue/gray= oil; white=coolant) Running it this way for to long can prematurely kill/clog your catalytic converters. This might be a fuel table problem in the PCM. Or if the O2 sensors are going bad it also can affect the fuel load.
