SCT not coming on
Old Apr 15, 2010 | 07:48 PM
mitch150's Avatar
SCT not coming on
Just figured I'd post on here to see if anyone had the same problem before I called Troyer . Tried to change tune today and my Xcal ll won't come on at all. Anyone have any ideas as to what the problem is? This will suck if I can't change it back to stock to if I ever have to take the truck to the dealership.
Old Apr 15, 2010 | 07:56 PM
shotgunz's Avatar
Did you check the fuse - should be the same one as your cig lighter, but check your owner's manual.
Old Apr 15, 2010 | 08:08 PM
JackandJanet's Avatar
Shotgunz's suggestion is the one I'd have given too.
It makes no sense to me, but Ford put the OBDII port and the cigarette lighter on the same circuit.
- Jack
Old Apr 15, 2010 | 08:15 PM
mitch150's Avatar
Thanks shotgunz, should have thought of that myself. I'll check it in the morning, I know the cig lighter fuse is blown so that would explain it! Thanks again, will post as soon as I check it.
Old Apr 15, 2010 | 08:17 PM
shotgunz's Avatar
Sounds like you have it licked!
MGDfan Junior v1.0
Old Apr 17, 2010 | 05:10 PM
mitch150's Avatar
Yep, it was the fuse. Got it going again, thanks again shotgunz and jack for your responses, much appreciated.
