About to buy a 2010 F150
I don't drive hard or fast, but I can't believe how sweet it moves with little input on the accellerator. The shifts are firm, but quick. It seems it shifts quicker to the next gear when I am light onthe throttle, but a simple easy push on the go pedal moves the truck easily without the need to downshift. If you do get into it a bit more to facilitate a shift, it scats.
I will say, it takes forever to initially download the ECM... probably 40 minutes. Downloading the custom tune to the PCM takes time as well... about 10 minutes. I reset to stock to see how long it would take, and that took about 7-8 minutes, as well. That's much more that my Xcal2 did with my 2008, but this 2010 is so advanced over my 2008 it isn't funny.
Great job, Bill!
Well, as of yesterday, I am PHP tuned. You 2010 owners will be impressed! I did get one simple CEL code Bill is working on, but it's nothing important. I hould have a re=write today. This is an 87 Performance. An 87 Tow is suppose to accompany the revised 87 Performance tune, as well. WOW! Thats all I can say... WOW!
Please give more information!
Its not a gryphon its a SCT Xcal3.
PHP sells these also upon request only.
They aren't listed on their website.
You need to call them.
SCT is the only custom tunable programmer on the market right now for the 09-10's.
Troyer and VMP also are offering them too.
Hmmm. Well, mine now has an extremely VERY touchy go pedal. It takes off with no lag. Infact, I have to change my drive style to be even more easy off the line, or it pushes me back like it used to when I I'd stand on it. There is absolutely no hesitation at highway or interstate speeds when running a hill... you know that feeling of having to dip into the throttle to get it to downshift to make a grade? GONE. Now, a totally different truck. Very light on it's feet.
Great job, Bill!
Great job, Bill!
- Jack
Nah - just use the MGDfan junior v1.0 method.
Eight D cells taped together (duct tape, of course) with pieces of coat hanger taped to the + and - ends.
Works like a champ and you can save the battery charger cash for more...
wait for it......
MGD!
P.S. This method is fully endorsed by both MGDfan V5.0 (you know - him) and MGDfan Junior V.88.
P.P.S. If you're really worried, tape nine batteries together.
Great job, Bill!
Great job, Bill!
) but the lazy feeling drives me nuts. Stock it feels “unfinished”. It sounds like yours runs great. I’ll go through the same guy you did for sure. Am I correct I the assumption that you have “canned” tunes and didn’t get custom dyno work done?Thanks for your reviews. I have only had the truck a couple of weeks and it has been very underwhelming. You certainly have provided a light at the end of the tunnel.
Do you have a number/link for PHP? I don't even know what it stands for.
Great job, Bill!
Great job, Bill!
. I really need to give them a call and order one. Mod the jet skis or mod the truck, decisions decisions
That sounds fantastic. I don’t drive my truck fast at all either (that’s what the Mustangs are for
Bill Cohron will write "custom tunes" for you. They won't be "dyno" tunes, but they will be based on your truck's specifics and your driving style and driving needs.
There are certainly others here though, that can possibly give you what you need. Troyer and DiabloSports come to mind.
- Jack
Great job, Bill!
Great job, Bill!
When you specified what tune you wanted, what exactly did you ask for? A general 87 tune, or something more specific. I'm looking to go to PHP soon for a tune and just wanted to make sure I asked for the right thing
NC - start by reading the stickies on this forum. They will answer 90% of your questions.
Then head over to PHP's forums (http://forum.gopowerhungry.com/) and peruse the GOBS (that's a MGDfan v5.0 term) of posts, reviews, questions, answers, etc. They will answer the other 10% (and provide answers to questions you didn't even know you had).
I'll double check the times tonight when I reload the modified tune. The initial capture of the original stock tune took the looong time. These 2009+ trucks load several programs in each tune, not one like the pre-2009's.
I'll have to admit that my anxiety level is really high when loading this tune just because the 2010 is such a different animal from what I was used to with my other earlier F-150's. When I look at the tuner and it says "Loading ECM" and then a few minutes later it says "Loading TCM", and then a few minutes later it still is going, my blood pressure spikes. I begin to wonder if something is wrong. Then, on start-up after loading the tune, it cranks for a while before starting. That's the real kicker. But, Bill at PHP confirms the truck is just resetting the cam sensor and other things. Then she fires up fine. Sure makes me jumpy, though.
I ordered an 87 Performance tune and an 87 Tow tune from PHP.
Don't delay you 2009+ owners. I think you all will be very impressed.
Yep - normal ... these have a separate TCM and everything is CANBUS interconnected - not exactly the fastest interface - and the SCT flashers are more geared towards reliable flashing than speed.
Flashing speed has never been one of my criteria. I prefer reliability over speed any day.
Good advice earlier - hook up a small maintainer - Schumacher, $19 @ yer local WallyMart works great.
Great results - thanks for posting this - it helps to reiterate that Bill can do superlative custom tuning on SCT hardware as well as Edge hardware.
MGD v5.0
wait for it......
Sorry,
Following this
MGD!
(Hopefully, they live through the experience.)
