Comparison Data - Stock vs. VMP 93
Old Mar 16, 2010 | 07:54 PM
Ragged05FX4's Avatar
Exclamation Comparison Data - Stock vs. VMP 93
So I got an updated tune from VMP today after throwing some DTC's with my current tune not liking my old AF1 (no insert), and after I got it, I shot over to SCT's website to see if they finally had Windows 7 64-Bit support yet (they do). So after downloading the new tune, I also got LiveLink for my laptop since I couldn't run it before. I had some extra time tonight so I figured I'd compare the stock vs. tuned numbers on the data logger. I wanted to check 0-60 and 35-55 numbers but also logged some other stuff that sounded interesting..
- I am in no way, shape or form, an experienced tuner, I have no idea what some of this crap means. I just did it for fun when I was bored.
- I calculated 0-60mph by using the timestamp that showed the first increase over 0.00 mph on the vehicle speed log until it hit over 60.00mph.
- I calculated 35-55mph by setting cruise at 35mph, then applied full throttle. I determined the timestamp by where the first increase of engine RPM was logged.
- My engine's warm up cycle was complete before both tests.
- I used the same stretch of road and same launching technique (slight break torque until 2000 rpm, released break, mashed throttle.
- I did two runs on each tune and kept the best of two.
- Each test I had my 3" AF1 and MagnaFlow 2.5" SISO installed.
LiveLink Results...
-STOCK -
0-60mph: 10.97 sec
35-55mph: 6.09 sec
Calculated Net Torque (MAX): 342.23 ft/lbs?
Engine RPM (MAX): 5037.79
EGO Temp (MAX): 1619.06 F?
Actual Air Flow (MAX): 30.28
-VMP 93 PERFORMANCE TUNE-
0-60mph: 8.44 sec
35-55mph: 4.16 sec
Calculated Net Torque (MAX): 426.33 ft/lbs?
Engine RPM (MAX): 5242.92
EGO Temp (MAX): 1583.01 F?
Actual Air Flow (MAX): 34.47
Noob Conclusion: Like I said, I don't know if the other readings are relevant, but I do know 11sec 0-60 is CRAP! I must have the worst stock tune on my truck because I even posted on here when I first got it thinking it was a dog compared to my 05' FX4 and 06' Lariat. If EGO Temp is what I think it is, then the tune actually lowered my exhaust temps at the 02 Sensor?
**I also just realized I'm just a third of a second faster then what my truck should do stock if I didn't have my BFG's lol
Old Mar 16, 2010 | 08:40 PM
ONELOWF's Avatar
Nice improvement. It sounds like a fair comparison of the logs.
Yes, with more fuel added and timing corrected, you should see lower egt's.
Old Mar 17, 2010 | 01:10 PM
Thanks for posting those numbers!
Looks like a good improvement.
Peace!
Old Mar 17, 2010 | 04:14 PM
XtremeBawls's Avatar
Good to see some comparison's of stock vs. custom tuned
Old Mar 17, 2010 | 04:43 PM
Raptor05121's Avatar
You gained 84 ft-lbs of torque with a programmer? Sounds ridiculously high from the dyno graphs I've seen
Old Mar 17, 2010 | 04:55 PM
^^I wasn't the only one who found those numbers a little high? I don't know much about programmers so maybe I'm wrong but that seems like a heck of a gain.
Old Mar 17, 2010 | 05:34 PM
mdhawkin's Avatar
I believe the dyno results are calculated at the rear wheels. Those numbers appear to be at the crank. If you do a simple ratio of stock crank to dyno numbers, I believe they are pretty accurate. I have only ran my truck on the 0-60 test one time and broke traction off the line but ran a 7.15, I think if I hook up I can get into the high 6's, still running stock tires though.
Old Mar 17, 2010 | 08:36 PM
I never had it dyno'd, as I explained in the post, all those readings were from the SCT LiveLink PID Software. I didn't think you could get torque numbers from just hooking up to the ODB-II port, or am I wrong? Like I said I'm a noob
Old Mar 23, 2010 | 01:01 AM
flaresidefx4's Avatar
yes you can get accurate torque readings via obd11 port. your transmissionis equipped with a load sensor and delivers the readings to your pcm,from there the pcm can calculate various shift points and patterns to optimize acceleration and effiency.
Old Mar 23, 2010 | 06:37 AM
Windsor's Avatar
Many of the transmission functions are based on torque output which is a calculated number based on load/rpm. You aren't making 400 lb/ft plus of torque, but you're exceeding the normal load ouput of the stock engine.
