woah. check this out
lol well in the event that my MAF goes out, that just gives me a good reason to upgrade it
idk how it would have caused problems with the tranny if it changes air/fuel ratio. lol but we'll see. my tranny only has about 25K on it. its still pretty fresh.
im curious as to how much (if any) hp it will make. like real dyno numbers..
idk how it would have caused problems with the tranny if it changes air/fuel ratio. lol but we'll see. my tranny only has about 25K on it. its still pretty fresh. im curious as to how much (if any) hp it will make. like real dyno numbers..
Oh my, I can't believe all the money I spent in a quest for more power and I didn't believe the add on ebay. Foolish foolish me.
lol
Some folks obviously have no idea how a PCM works or any of the sensors associated with it. You can temporarily fool the PCM in to believing the intake air is colder than it is. It will adjust the AF mixture accordingly and then when this faulty mixture gets to the 02 sensor its all over with. The PCM will countine adjusting until it figures out the inlet temp is wrong and throws a check engine light for the sensor being bad. It will the run the engine off of the info coming from the MAF and the 02 sensors. So now someone is probably thinking 'duh i'll just get rid of the 02 sensors'. Honestly if you hate your truck this much just drive in to a swamp. As has been stated if you can afford real mods you certainly can't afford broken s*^t on your truck now.
Horsepower cost money!!!!
lolSome folks obviously have no idea how a PCM works or any of the sensors associated with it. You can temporarily fool the PCM in to believing the intake air is colder than it is. It will adjust the AF mixture accordingly and then when this faulty mixture gets to the 02 sensor its all over with. The PCM will countine adjusting until it figures out the inlet temp is wrong and throws a check engine light for the sensor being bad. It will the run the engine off of the info coming from the MAF and the 02 sensors. So now someone is probably thinking 'duh i'll just get rid of the 02 sensors'. Honestly if you hate your truck this much just drive in to a swamp. As has been stated if you can afford real mods you certainly can't afford broken s*^t on your truck now.
but do YOU have any data showing it doesnt work.
have YOU personally tried it.
yall dont know if it will or wont work because noone has tried it. you assume because its from ebay that its a pos. (which it may be)
i dont have a problem trying it out. if it hurts my truck and repairs are needed ill asses the situation when the time comes. i appreciate the input giving but i feel like yall have no known evidence backing it up. seeing as noone has actually given it a try, theres no proof to it not working.
if it doesnt work, you can say i told you so.
now i understand that it is just some cheap item off ebay but it may give me a bit of a gain with no problems at all for the life of my truck. IF thats the case, then i believe i spent 25 bucks well. if not, ill have costly repairs to make.
yeah he means if the resistor does end up messing it up, while he is replacing it, might as well upgrade.
but wouldnt his reply be...i cant hold yers, my hands got 2 of my own.
Guys, there are some people that just refuse to be helped. They have to learn the hard way. Look at it this way, he will have something to laugh about and tell his kids someday. When they are about to do something dumb, and they say, "here, hold my beer and watch this", he can say, "hey, I once bought this diode........"
" ... and this here diode ( resistor, actually), is why, Johhny, I couldn't send ya off to College, on account of the engine done blowed up and I spent all yer school funds fixin' it ....."
Oh my, I can't believe all the money I spent in a quest for more power and I didn't believe the add on ebay. Foolish foolish me. lol
IF the sensor was SHORTED or OPEN, then the PCM can detect a faulty unit and run in limp-home mode with a CEL.
Otherwise, if it is giving any resistance reading at all within a very wide bound ( as the truck can run in either Arctic or Sahara-like conditions), then the PCM ha NO OTHER WAY of knowing what actual ambient is. It is the ONLY temp input the PCM has - so it MUST be accurate.
hey, just noticed you already have a cold air intake. just letting you know that the chip does the same thing as a CAI except without actually having one. the chip tricks your computer into thinking it works, your intake actually works. sorry for not catching that before...so with that info, you will probably get no power or actually lose a little. by the way, do you have an open filter or closed filter for your CAI? because either way i can suggest something to help out a little.
I do not think this is the case ...
Use the search feature here. There has been many discussions about these items, how they work and the potential damage caused. If you want to ignore all the warnings go ahead but the repairs are going to cost you a lot more that the 25 bucks you have wasted on a 10 cent resistor. There are web sites that show you how to wire in the 10 cent resistor and save yourself $24.90. Do some research and listen to peoples' advice. I do not have to try jumping off the Empire State building to know it is bad for me.
