Speed-O Correction...
Old Jan 30, 2010 | 12:36 PM
Jrc985's Avatar
So i recently updated my edge and now have the option to correct tire size to fix the speed-o and when i changed the size to the recommended for 35's it was even more off then b4, like 7 higher then i was actually going?
i have 35x12.50x18 toyo mt's what do yall recommend i change the settings to
Old Jan 30, 2010 | 12:43 PM
Make sure the gears are correct, and then just change it till you get it correct. I would make the first change about 10%, assuming the gears are correct.
Old Jan 30, 2010 | 06:11 PM
JackandJanet's Avatar
I'd suggest a Tire Size of 2709mm as a start. If your speedo is saying you're going faster than you really are, the TS you were entering is too large.
- Jack
Old Jan 30, 2010 | 06:52 PM
Jrc985's Avatar
thx, will try that and report back with the results
