Do I need a custom tow tune?
As soon as PHP is back from their medical emergency (Hope all is well) I'm going to upgrade my Edge to a Gryphon. I plan on getting the 87 performance custom tune - I'm running the Edge 93 perf tune right now on my 06 with Volant CAI and cat-back duals. Gas prices are getting back to where the higher octane price will make the custom tune worth it.
But, I also tow a 6x10 enclosed utility trailer with maybe 750lbs of weight in it maybe 20 times a year. Right now I just leave it in performance mode and GO! Should I also get a custom tow tune? Is the stock tow tune satisfactory? Do I even need to change - can I just operate in the 87 perf tune once I have it?
Thanks for the advice.
I am not an expert by any means, but Im going to assume that 750lbs is nothing for these trucks but since you hv a CAI, you may hv to get a tow tune. If i remember correctly, it was inadvisable to tow while having a performance tune loaded in the EDGE. I would assume it would be similiar for a Gryphon
To the OP:
You need to figure out your total combined weight of the trailer and payload.
Edge/Gryphon performance tunes are only rated up to 2500 lbs for towing.
The edge towing tune would be better.
[QUOTE=88racing;4059070]To the OP:
The edge towing tune would be better.[/QUOTE
I'll check empty weight of the trailer though I doubt combined weight will top 2500lbs. Good news is the PHP folks are back. Bad news is I still probably need to wait a week or two for them to get caught up.
Sounds to me as if I can probably get by with just the one custom tune - the 87 performance, and use the standard towing tune?
