Display on gryphon not working
As the title says the display on my gryphon isn't working. Started my truck the other morning to go to work and the display is blank, no lights nothing. Has anybody had this problem?
Check the cable connections.
Check the cigarette lighter fuse. This same fuse powers both the lighter and the OBDII power supply.
- Jack
It could be the unit itself going bad...could be a bad cable especially if your truck is an obs...But first you need to go check the cigarette lighter fuse, if its blown it kills the obII port also. Hope this helps
Edit: I guess Jack beat me to it...and good point about the connections.
