how to tell if superchips 1705 is locked
well my dad found his old superchips 1705 for a 7.3 PSD but is not sure if he set it back to stock, how can i check besides plugging it into another 99-03 PSD? the cable on it has a computer style 9 pin connector, but my computer does not...i could get an adapter if plugging it into my computer will do anything
That's not a serial port (they are just using the same style connector) - so plugging into a pc will do SFA.
If you connect to any OBDII port on any older Ford - NON-CAN bus - must be Ford & NON-CAN bus due to the specific OBD protocol in use - just to power it up, you should be able to tell - I think it will display something to that effect ... will not hurt anything to try.
Hi AZ.
ok just found a pdf of the owners manual and it says that it will say vin locked before it goes to ask to begin
http://www.thoroughbreddiesel.com/su...ation/1705.pdf
so sounds like it is unlocked....i think
Yep - the O2 MY is non-CAN. You will avoid the connect error on that truck, and it will say as you stated above, if unlocked. Hopefully!
Good luck
