another x3 question
Old Jan 1, 2010 | 09:10 PM
ridinmudddy's Avatar
another x3 question
what are the spark adjustments for? like what would happen if i increased or decreased the number ?
Old Jan 2, 2010 | 01:03 PM
JackandJanet's Avatar
It almost HAS to be an adjustment for spark advance. If you retard the spark, you'll probably lose power and see reduced gas mileage. If you advance the spark, you MAY see just the opposite, unless you overadvance the spark. If you do that, the PCM will compensate by retarding the spark a bunch to prevent detonation, and you'll be back in the loss of power column.
- Jack
Old Jan 2, 2010 | 04:18 PM
Veteran: Army
when you load your tune it's in the adjustable perameters, don't mess with it unless you know what you're doing...
Old Jan 2, 2010 | 05:16 PM
Marc Carpenter's Avatar
Spark is timing. Most reputable tuners will only give you 1 or 2 degrees either way which should not enable anyone to get into any major trouble.
Old Jan 2, 2010 | 07:34 PM
oh okay i didnt wanna mess with it without knowing what it was but thanks guys
Old Jan 4, 2010 | 12:19 AM
FordRacer2005's Avatar
In other words don't mess with it.
Old Jan 4, 2010 | 12:39 AM
yeah i think im gonna just leave all that up to troyer.
