Question about speedometer correction when flashing back to stock tune?
Hi,
I have a 2006 5.4L F150 XLT 4X4 with custom VMP tunes. It has 2" Bilsteins and and add a leaf in the rear. I will be putting on larger tires in a month or so...stockers are 32" and I will be moving up to close to 34".
I know that I just change my revolutions per mile in my XCal 3 and reflash the truck when I put the new tires on.
My question is what happens when I take it to the dealer? I always reflash my truck to stock before taking it in for service. If I do that my speedo will be off by quite a bit and it will not be shifting as well. Is there a way to only modify the revs per mile on the stock tune when I set the truck back to stock or am I stuck with it being off? I guess it shouldn't be a big deal for only that short time frame but I figured I would ask since many others here must deal with this issue some how. Any advice is appreciated. Thanks!
I figured I would be fine since it would only be a few miles off at 60 mph. I just thought others on here might have had a way to deal with this problem. I see no reason to chalk up the money since I have the X3 but can't the dealer change the stock tune for larger tires? If someone does not have a programmer and puts on larger tires I would think the dealer could do it but they charge a lot of money for something so simple. I think I'll just deal with driving around for a day with it off about 6%. Thanks everyone for the responses!
Good question. I am curious myself. Speed and RPMs are connected though...if you put a larger tire on then you will run the engine at lower RPMs for a given speed. If shifts are based on RPMs then correcting the speedo will do nothing for my shift points. If they are based on speed then correcting the speedo will help the shifting with larger tires. Can anyone else chime in on this?
I'm kind of simplifying here, but this is the basic control system. It's a balancing act between speed and throttle. It is not governed by RPM unless you are in a WOT condition (somewhat above 90% open throttle). Then, it's totally controlled by RPM.
- Jack
I'm guessing that a dealer reset of TS or GR might change the HEX code, it may not. I DO know if a PCM is reflashed it causes the custom tunes in a Gryphon to be rebuilt. I think it's reasonable to assume the same might be true of an X3 or other custom tuned programmer if the HEX code changes.
- Jack
p185, the info used for tire size and gear ratio is stored in a seperate data table than the timing and fuel uses. When you flash the trucks PCM, you have the option to alter the TS and/or GR. When you change them, the new values stay even when flashed back to stock. So you could reload any of your tunes, adjust your TS/GR, and when you go to the dealer, put your truck back to stock and your TS/GR will not revert back to stock. The only time these values changwe is when you change them.
Bill (ASE Mechanic) knows exactly what I'm talking about and could probably explain it better than I can.
-Pat
Here's what I think Bill has told me:
1. You load any kind of tune and don't try to manually set any custom options such as TS or GR, then the tune gets those values either from the VID section of the PCM (which was fixed at the factory) or from the tune itself since a custom tune can set a "flag" that tells the tune compiler to ignore the VID completely. It does not load any "custom" TS or GR YOU set previously.
2. You open the "Custom Options" menu (it's called this on a Gryphon or Edge and I don't know what it's called on an X3 or other programmer) and you get "placeholder" values that may or may not be correct. Now, this is what happens on a Gryphon/Edge - the X3 may well be different!
3. As far as I can tell from everything Bill has told me, NO CUSTOM TS or GR values are placed into other tunes (including stock) unless YOU put them there manually.
So, I'm just not sure what you said in the part of your quote that I bolded is correct. And, maybe different programmers handle this differently too!2. You open the "Custom Options" menu (it's called this on a Gryphon or Edge and I don't know what it's called on an X3 or other programmer) and you get "placeholder" values that may or may not be correct. Now, this is what happens on a Gryphon/Edge - the X3 may well be different!
As I said, I'm not trying to start a fight, but would like to find the truth in all this!
- Jack
Hey Jack, no offense taken. I was trying to explain it in laymens terms to the best of my ability. I'm not sure exactly how the whole system works, thats why I'm not a tuner. But I do know that the TS/GR info is stored in the VID (as you called it) and can be changed along with the tune or by themselves. Once the TS/GR is changed, the new value stays until you change it again, regardless of what you do with the tune, such as return to stock, or load another tune, or leave it alone.
I guess the best way to look at it is its like the PCM has 2 EEPROMS, one for the tune and one for the VID, each can be reflashed independently or together. It's almost like flashing the BIOS on your PC except the PCM has a dual bios that stores different data in each versus a PC w/dual bios that stores indentical data in each (mainly as a back up in case of corruption)
If, of course, you can flash the VID section, then anything I'm saying is completely false. I'm certain Bill told me that is not the case.
We'll get to the truth of this matter eventually, won't we?
- Jack
Like I said, I'm not exactly sure how it all works, but if the dealer can change info in the VID block (like TS or GR or other vehicle specific info) then my best guess is you can reflash the vid. Whether the egde (or X2, X3)actually reflases the vid block or tricks the pcm into thinking it has really doesn't matter. As long as we know that the altered TS/GR data will stay when you go back to stock.
Kinda like 6 of one half a dozen of the other, no matter how its done well get the same result in the end.
