buying an edge!
buying an edge!
going to pick it up tomorrow! 3 months old and the guy is getting a new ride so he is selling it to me for $265 and it comes with everything including the pod! he already set the truck back to the stock tune! wow I am pumped....probably upgrade it to the gryphon at some point!
We're talking programmers here and custom tunes, not "chips". A good custom tune can net you gains of 35 Hp and 45 ft-lbs of torque, if you have a late model f150 with a 5.4L engine. Earlier models or ones with the 4.6L engine show smaller gains. And, if the tune is written by a competent tuner like Bill Cohron or Mike Troyer, it's ALL good.- Jack
My stock 4WD F150 XLT SCAB 4.6L with the 3.73 rear barely gets out of its own way. No programmer is going to make it as fast as my previous hemi RAM 1500.
That said, I still prefer the F150 over the Dodge, but it's close.
If you had a hemi, why did you get the 4.6? Not flaming, just wordering. Must had got a smokin deal I bet.
OP, you will like the edge. I just took mine back to stock because I am getting ready to gryphon it and it sucks to drive now, but not as much as when it was stock!!! Congrats!!!
LOL the hemislayer name was when i made the account in 2004 .... I had a 5.4 with a few mods then. I just got a 09 with a 4.6 wish it had the 5.4 but all i can do now is mod the crap outa this 4.6 and see where it gets me. I figure if i do pretty much all the bolt on mods and the gryphon tunes it'll run close to a stock 5.4
well i picked up my edge tonight and had it installed and setup in less than a half hour! just had to figure out my tire size in mm's (2610) and my gear ratio which end up being 3.73LS.....so far I love it....just need to figure out a better way of holding it down! the 3m double sided tape just isn't doing it for me!
The 4.6 isn't bad unless I'm pulling a trailer or a load of mulch in the bed.
I too, am curious what a programmer might do for the 4.6.
I can only quote numbers from PHP's website. They say gains of up to 25Hp and 40 ft-lbs of torque for 4.6L and 5.4L 2V engines. I suspect results from any competent tuner, such as Mike Troyer at TroyerPerformance will be similar.
- Jack
- Jack
