another edge question...
Old Apr 8, 2009 | 09:00 PM
chris1450's Avatar
Hopefully someone knows. When I have my truck tuned to the level 2 setting, I want to firm up the shifts a little bit. I go to the create program area, pick the shifts I want to change, and the default is zero. Now when it says zero, is that absolute "zero" or is it zero and anything above it firms the shift more than level 2 programing? I think it is absolute zero.. maybe from stock. I set 1-2 shift to 8 and it didn't seem as firm as when the canned level 2 shifts. Yet when I go to richen the WOT fuel, it comes up automaticly with 1.32. Now that seems like the level 2 base by aperances. What gives? Does that make any sense? Any help would be apreciated.
Old Apr 8, 2009 | 11:26 PM
On the shift pressure, 0 uses the setting that is in the current program as the starting point. So whatever you add starts with the Level 2 shift firmness. I always ran +12, +12 and +9 before I got custom tunes. Ran the same on Level 3.
Old Apr 9, 2009 | 08:37 PM
chris1450's Avatar
Thanks Bluejay. I tryed +8 +8 and +4 first and it seems just like stock. Now I am at +15 +15 and +12 and it still doesn't feel as tight as the level 2 program. Hmm...
