Datalogging with Autometer wideband
Old Apr 8, 2009 | 08:50 PM
Klitch's Avatar
Autometer wideband's have the voltage output range of 0-4v or something to that effect. what is necessary to get that signal to a pid using sct livelink through the xcal 2?
Old Apr 9, 2009 | 12:20 AM
ONELOWF's Avatar
You can configure the equation in Live Link......drop down under Commands. But you need to have mini din seven pin connector to hook to the WB to the XC2. Pm sent.
Old Apr 24, 2009 | 06:37 PM
Klitch's Avatar
have a problem now, i have my cable, checked my wiring and its correct this time. problem is the a/f output is only .14v no matter what the gauge says. help?
Old Apr 25, 2009 | 10:17 AM
ONELOWF's Avatar
How are you measuring the voltage?
In Live Link, verify that the STFT's are 1.0 (14.67) at idle after the cold start function is finished....about 45 secs. The readings will bounce around, but the o2s will keep it close and try to maintain the 1.00.You should be able to verify this and compare the STFT readings to the WB readings as a check.
Old Apr 25, 2009 | 09:10 PM
Klitch's Avatar
probed the output blue and blue/black wire and received .14v from the a/f meter.
