cutting out
cutting out
have a 07 with the edge only in stage 3 around 55 or 65 mpr it startes cutting out bad when you try and hold it around those speeds if you turn over drive off it seems to go away it dont do it on andy other stage or stock.
if you have the 5.4 then you need to put the stock intake back on, you're probably running way lean (common problem with a CAI and non custom tune)
if you have the 4.6 you need to check the cops
