VMP tunes....
Old Mar 5, 2009 | 07:25 PM
midnight08's Avatar
VMP tunes....
VMP tunes ordered today.... we will see what this 5.4 reg cab can do.... was running low 15's at the track completely stock. hopefully ill get into the 14's with the tunes...
Old Mar 5, 2009 | 07:54 PM
Ace85's Avatar
Low 15's that is fast.. the VMP tunes should help you alot especially the launching and higher revs, faster shifting will probably put you into high 14's, that is if you dont spin through 1st.
Old Mar 5, 2009 | 08:31 PM
atthelake27's Avatar
Let us know how your results turn out and how long it took to get your tunes. Im guessing your getting custom tunes correct?
Old Mar 5, 2009 | 09:27 PM
spike747's Avatar
With a tail wind and down hill?
Old Mar 6, 2009 | 12:06 AM
midnight08's Avatar
at the lake.. will do
spike... nope..
15.157... 53 degree perfect weather.... done at gainesville raceway on an extremely well prepped track.. launched from idle... no wheel spin... about as good of a run as that truck will ever run stock.
let me guess... you are running a lariat supercrew... that would put you around 15.7-15.9 in the 1/4
im running a regular cab, short bed, flareside, FX2 with 3.73's on stok 18's and stock rubber with the 5.4L. my truck as described by fords description on their website puts your truck at 500lbs heavier than mine. the old addage... for every 100lbs you loose a 1/10th.... if im running a best of 15.1 your 500lbs heavier... best for your truck by those "rules" would put you at a 15.6... give or take a couple tenths for driver error, weather, and track prep.
Ace85... I am thinking that wheel spin will be a problem at the track. i couldnt launch the truck from anything but idle or the wheels would spin and that is with the truck being stock... when justin fixes the open loop (torque management system) problem with these truck i think traction will be a real problem on stock rubber. but i should still pick up a tenth or two after it hooks back up.
Old Mar 6, 2009 | 12:52 AM
Ace85's Avatar
Just do a crucial burnout before you line up, that should get the tires nice and sticky! Im pretty sure screw lariats run about 1 second slower then the times you were saying.
I want to bring my screw to the track just to see what it will run. Its got VMP tunes exhuast and intake Im hoping that it will break 16 seconds.
Old Mar 13, 2009 | 08:48 PM
midnight08's Avatar
justin got them to me in a week. have not tried them out yet as i have to finish the suspension on the truck.
Old Mar 13, 2009 | 09:10 PM
i.ride.suzuki's Avatar
Crucial? LOL
Go around the water pit. A burnout won't help unless you have the right tires.
Old Mar 14, 2009 | 12:20 AM
midnight08's Avatar
yeah... i know about the right tires... the stock tires that i got will just burn and then cool imediately. there is nothing that i can do to improve the 60' until i get better tires. but that wont happen as the truck isnt fast enough to be making it to the track every week.
Old Mar 14, 2009 | 01:12 AM
Ace85's Avatar
Weird every car I have driven has always hooked up better after doing a burnout.
Old Mar 14, 2009 | 03:51 AM
wxscpo's Avatar
What you haven't got them things installed yet!
J/K let us know how they feel and what difference they make.
Old Mar 14, 2009 | 11:57 AM
midnight08's Avatar
nope... havent installed them yet. I am putting the front coils in today and will be getting an alignment sometime early next week. i will probably have a tank of 87 still in the truck so i will try out the 87 perf, and the 87 tow. then try out the 93 perf
Old Mar 15, 2009 | 02:36 PM
JeremyGSU's Avatar
spike... nope..
You are too generous to a supercrew! lol On 18's and 3.55 gears with exhaust and edge on level 2 I ran a 16.9
Then I switched to oem 20's which should have made it worse. To run 15's with the 20's I had:
93 VMP performane dyno tune
AF1 3.5" intake
2.5" custom exhaust
4.10 gears
removed tailgate/full spare
that netted me a 15.7@87 at Bithlow
I wish my truck ran low 15's stock!
Old Mar 15, 2009 | 02:43 PM
midnight08's Avatar
i was just easing on the safe side. but i am surprised they run those times. when did you run at bithlow? good weather?
Old Mar 16, 2009 | 03:16 PM
midnight08's Avatar
getting an alignment tomorrow.... will install the tunes tomorrow as well.
