Dealer Reflash
Dealer Reflash
Going in for some warraty work what happens if the dealer reflashes without my concent.I will return tune to stock but if they reflash i will have a new stradigy code then what? I can read the new code and sent to 5 star to see if the new code is compatable but what happens if it isnt?
From what I understand you'll be fine. Like you said, return it to stock. Let them do whatever they need to do including reflashing. When you get it back reload your custom tune and your good to go. Simple as that
Maybe, maybe not. If it's like the Gryphon, the custom tunes depend on the PCM's hex code, which changes if the dealer does a reflash. If all you have on your programmer are canned tunes, you're probably ok.
- Jack
- Jack
if it's deemed necesarry by them to solve problem by reflashing it- they will ,or they will note that customer did not want a reflash , and it will be noted on repair history that they attempted to solve problem, that customer didn't allow this to happen...
Oh, I thought the hex code was a permanent thing. I didn't realize that it changes when re-flashed. That's a pita.
