Happy with edge evo?
gryphon, for the custom tunes and awesome customer service, Yes I bought an Edge but I'm not going far past stock, Just wanted some power, MPG+, and better shifting when I tow. If I was lifting and bigger tires I would def bought a gryphon.
- Jack
and things change..... I updated the firmware online, all went smooth as could be. Upon reinstalling the Evo in the truck, it sits there like a piece of dead plastic requesting that I wait for it to initialize. Half an hour later, same screen. Product definately WORKED well, now the firmware on the other hand, it needs a little help. After being a proud owner for a couple of days, I have a stock calibrated truck and have to contact tech support Monday to see what can be done. FROWN
- Jack
But - I think you WILL be able to get this fixed, you just have to be patient! And, I know this is hard!
In the end, you will be happy you have a programmer!
- Jack
Nope, no custom tune here. Im all about having a programmer, just having doubts about the company I have chosen to go with. Things like this happening after this short of a time tend to leave one second guessing their decision. A good thing would be a means to recover from a bad flash without having to deal with tech support.
Just wanted to make you aware that Authorized Edge Dealers should not be selling the Evo for less than $399, so if anyone is, just be wary.
(We verified this information less than two weeks ago.)
As far as the hp gains are concerned, you can bet your booty that they're for real -- my husband did the dyno testing when he worked at Edge.
You can check out dyno plots from the 2009 F-150 right here. He was just at Edge for 10 days datalogging and dyno tuning.
If you're looking at a used Evo, please check this out first, as it might possibly save you a costly unlock fee.
(We verified this information less than two weeks ago.)As far as the hp gains are concerned, you can bet your booty that they're for real -- my husband did the dyno testing when he worked at Edge.
You can check out dyno plots from the 2009 F-150 right here. He was just at Edge for 10 days datalogging and dyno tuning. If you're looking at a used Evo, please check this out first, as it might possibly save you a costly unlock fee.
Just did some verifying with Edge -- they're not supposed to be selling them for less than $399. Whether they are or not is a different story...
Great! I'm happy you solved the problem! Did you have to use a "previous" firmware update?
- Jack
- Jack
