Edge issues
Old Jan 21, 2009 | 10:13 PM
mxguy54's Avatar
Edge issues
My screen tends to light up green and not show my displays. It is mainly after it has sat outside at work. Our temp. here has been above freezing and it still does it. Does anyone know if I have any options?
Old Jan 21, 2009 | 11:08 PM
blackf150337's Avatar
I've had these same problems...start my truck and it stay frozen at the evolution slash screen or start my truck and it just light up with nothing on the screen... i recently sent my back to edge because the screen quit working all together...i just got it back and it's freezing up all the time...contact edge products
Old Jan 22, 2009 | 06:59 AM
mxguy54's Avatar
Problem is..... its not new...
Old Jan 22, 2009 | 10:54 AM
JackandJanet's Avatar
From your first post, it sounds like the problem is intermittent, right? Sometimes, like maybe when your truck's been in a garage, the display is normal on start?
From several posts on this, I'm getting the feeling that the Edge is quite sensitive to cold weather conditions.
I'd call Edge regardless of the age of your unit though. They need to know about these problems and who knows, they MAY have some ideas. Perhaps Bill (ASEMechanic) will notice this too and post some thoughts.
- Jack
Old Jan 22, 2009 | 10:10 PM
Groovy Chick's Avatar
Former Sponsor
At what point does the display come back on?
Perhaps Bill (ASEMechanic) will notice this too and post some thoughts. - Jack
As close as you can get to ASEMechanic (he's working on custom tunes)!
Old Jan 23, 2009 | 06:54 AM
mxguy54's Avatar
The only time it will come back on is if I unplug it and replug it in, otherwise it will stay lit with just the backlight and not gauges. Also when this happens it doesn't shut off with the truck.
Old Jan 23, 2009 | 11:12 AM
Whups! That sounds like a somewhat low battery. When you unplug it and plug it back in, is the engine (alternator) running? If so, you'd have higher voltage available at the OBDII port and the Edge would initialize normally.
The Edge (and the Gryphon) are sensitive to low voltage and, as Bluejay said in another thread, you can take this behavior as an "early warning" of battery problems.
- Jack
Old Jan 23, 2009 | 10:18 PM
mxguy54's Avatar
Actually I only unplug it and plug it in when the truck is not running.... So it should still be coming off of the battery
Old Jan 24, 2009 | 12:28 PM
OK, I'm out of ideas now except back to my original one to call Edge.
- Jack
Old Jan 24, 2009 | 02:39 PM
mxguy54's Avatar
ya, I'll try that when i get off work early enough. It's been working good the last 3 days thogh!
