Edge [ Custom Options ]
Old Sep 26, 2008 | 04:40 AM
Sunshine B's Avatar
I have no idea about the edge programmer i installed.. but i need to have the custom options i think?
i have 35x12.5tires and 17" wheels on .. i have a 2005 lariat 4x4 5.4 v8
i run 95+ octane
can anyone help me out please? thanks..
Old Sep 26, 2008 | 02:39 PM
phatboyspam's Avatar
Unless you feel like changesare needed to your settings leave em alone.
But at the same time make sure you have the right tire size input, and that your on lvl3.
And if you really feel the need to to have your settings adjusted it would be better to upgrade your edge to a gryphon and have custom tunes created.
Old Sep 26, 2008 | 02:55 PM
i run 95+ octane
On level 3, the canned program is set for 91 octane. I would bump the timing +2, to take advantage of the higher octane you are using.
I would do a + 9 on the shift pressure and see how you like it. I always ran +12 except except on the 3-4 shift. +9 is as high as I would reccomend for it. If that is firmer than you like, drop back to a +6. I like firm shifts.
Do a +1.5 on WOT Fuel,
WOT shift points, I like 5250 for the first 2 and 4800 for the 3-4.
Max RPMS 5650 and max speed 110.
Normal shifts, I would not change.
As previously stated, change your tire settings and change the gear ratio if the default is not what your truck has.
Old Sep 26, 2008 | 02:57 PM
BTW, if you do not have a manual, go to Edge's website and download a copy.
Old Sep 26, 2008 | 04:37 PM
sharpshooter109's Avatar
bluejay, just out of curiosity, why do you suggest the speed limiter at 110? will it hurt the engine to remove it or would it help to set it lower?
Old Sep 26, 2008 | 04:46 PM
Because I have come real close to the stock speed limiter of about 95 on several occasions. I wanted to bump it up and I doubt I would ever want to go faster than 110, so that is where I set it. I just dont want the limiter telling me I can't go faster if I ever needed/wanted to.
Old Sep 26, 2008 | 04:48 PM
Ftruck05's Avatar
I think most on here would call it common sense. Why do you need to do 110 in a truck? I have my limiter at 130 though and only had enough ***** to do 112.
Old Sep 26, 2008 | 04:51 PM
I don't think I want to go over 80 on these Falken tires. Not impressed with them at all. They came with the wheels. I'm used to Michelins and would trust those to 130 for short runs.
Old Sep 26, 2008 | 05:26 PM
ok. yeah, i thought you were saying that 110 was better than 130 or higher. i dont think i will be doing going that high either. thanks.
Old Sep 26, 2008 | 05:46 PM
HAHA thats funny I'm running nitto TG's and theres been a few times I've done 110+.. scarey though.
Old Sep 27, 2008 | 07:04 AM
Sunshine B's Avatar
i just fixed my edge.. wow edge rocks
used to suck when i had it stock
thanks guys
Old Sep 27, 2008 | 11:24 AM
thanks guys
Glad you got it set. It is amazing what Ford left on the table with these trucks. A tuner makes them so much more fun to drive.
Old Sep 27, 2008 | 09:50 PM
blackedout50's Avatar
The trucks handle ok at speed I have mine set at 140 unfortunately I got a ticket for 115 on the way back from the drag strip.Laser is a killer.
Old Sep 27, 2008 | 11:04 PM
4.6 Punisher's Avatar
And you still have your license? In GA, if you are caught going over 100 MPH, you go to jail for 24 hours and you loose your drivers license for 6 months. That's what happened to my friend and now I make $50 a week off of him to take him back and forth to the campus, when it fits my schedule.
Old Sep 28, 2008 | 02:57 AM
Wow I got 4 points and $250 court cost. Thank god I had a radar detector the speedo was berried and I lit the brakes up when I saw laser. The cop laughed at my courtesy card. He was pretty cool considering I had My dial in times all ova the windows.
