Edge [ Custom Options ]
Old Sep 28, 2008 | 07:34 AM
Sunshine B's Avatar
Originally Posted by bluejay432000
On level 3, the canned program is set for 91 octane. I would bump the timing +2, to take advantage of the higher octane you are using.
I would do a + 9 on the shift pressure and see how you like it. I always ran +12 except except on the 3-4 shift. +9 is as high as I would reccomend for it. If that is firmer than you like, drop back to a +6. I like firm shifts.
Do a +1.5 on WOT Fuel,
WOT shift points, I like 5250 for the first 2 and 4800 for the 3-4.
Max RPMS 5650 and max speed 110.
Normal shifts, I would not change.
As previously stated, change your tire settings and change the gear ratio if the default is not what your truck has.
Is it safe to run all that on the truck?
Old Sep 28, 2008 | 08:55 AM
Ftruck05's Avatar
If it was'nt safe bluejay WOULD NOT reccomend those settings. I've been running my Edge on those settings for 15-20,000miles with no problems.
Old Sep 28, 2008 | 10:06 AM
Sunshine B's Avatar
nice
Old Sep 28, 2008 | 03:29 PM
Jon Bourget's Avatar
License removal
This topic would make an interesting thread. What does it take in your state , To have your license removed? I always heard it was if you doubled the posted limit they could arrest you and take your license on the spot , here in Massachusetts. Ive got lucky on that one.
Old Sep 28, 2008 | 03:36 PM
Except for the different timing setting, since we can get only 93 octane, I ran those settings for 35,000 miles, till I got custom tunes. Each truck is different and each person has different feelings about what they want. Those are suggested starting points and if anything is not to your liking, then adjust it. A guy at work ran +18 on the shift pressure. That was too much for me and I love firm shifts.
Old Oct 4, 2008 | 10:29 PM
Sunshine B's Avatar
alright im running a volant intake + edge programmer.. its working alright
where can i get a tune for my volant intake?
Old Oct 4, 2008 | 10:36 PM
Sunshine B's Avatar
plus im thinking of switching my 3.73's to either 4.10's or 4.56's since im running 35's tires etc ..
how much would it cost me?
best brands? links pls
mine is a 4x4
atm i have the ,3.73 limited slip (F-150, F-250)
Old Oct 5, 2008 | 09:13 PM
sharpshooter109's Avatar
the only place to get custom tunes for the edge is from php. it costs $25 plus shipping to have your edge converted to a gryphon, then $50 per custom tune.
power hungry performance
