problem with pcm
Old Sep 19, 2008 | 01:21 AM
fastfity's Avatar
problem with pcm
my truck is a 2006 screw 5.4 40,000 miles check engine light came on so i put my code reader on it and come up with is p0607 control module performance. if something is wrong with my computer how can i get it reflashed or checked out
thanks
Old Sep 19, 2008 | 03:10 PM
Buck50's Avatar
i would assume your still under warranty. Take it in. Don't bust your head figuring it out. let the dealer handle it.
Old Sep 19, 2008 | 04:04 PM
Drail's FX2's Avatar
P0607 Control Module Performance Detailed Description
Indicates that the powertrain control module (PCM) internal central processing unit (CPU) has encountered an error. The PCM monitors itself and carries out internal checks of its own CPU. If any of these checks returns an incorrect value, the diagnostic trouble code (DTC) is set.
Possible causes :-
Module programming error.
Aftermarket performance products.
Damaged PCM
this is from Ford website, do you have a programmer installed?
Old Sep 20, 2008 | 01:46 AM
fastfity's Avatar
no just a k&n and a banks exhaust. but the problen did start as soon as i recharged my k&n.
Old Sep 20, 2008 | 02:32 AM
ThumperMX113's Avatar
Clean your MAF.
Old Sep 20, 2008 | 08:18 PM
PhqChevys's Avatar
Originally Posted by ThumperMX113
Clean your MAF.
x2. you may have over oiled your K&N.
Old Jan 15, 2009 | 12:56 AM
fastfity's Avatar
so just a update on the code. i finally turned it in to the dealer on the 7th and they said the pcm had to be re flashed. so I'm like cool but then somehow they toasted my pcm instead but its OK they already got a new one on the way be here next day. two days later on the 9th they get the wrong part in but its OK they already rectified the problem they got the right part on the way but wait the part has been recalled and the part was returned. the latest and greatest wont be released until the 19th so i can expect to get my truck back no sooner that the 23rd. wtf??????
Old Jan 15, 2009 | 01:17 AM
Drkharbinger's Avatar
Sounds like head up a** syndrome to me. Morons. The PCM was recalled?
Old Jan 15, 2009 | 06:13 PM
fastfity's Avatar
yea or someone screwed pooch. ill talk to the dealer and get more info.
