Edge performance setting question
Old Sep 11, 2008 | 11:27 AM
fx4tough07's Avatar
I have the edge tuner on my 2004 ford f150 fx4 and i will be running premium gas on level 3 performance level, but if for some reason like my g/f is driving it and forgets to put premium in will it do any harm to my engine or anything. Thanks
Old Sep 11, 2008 | 11:56 AM
i.ride.suzuki's Avatar
Protip: Get a new girlfriend if she does not put in premium.
Old Sep 11, 2008 | 11:58 AM
Probably not if it is mixed with some 93 and it is not driven hard. If the engine is put under a load and the octane is not high enough, you will be running lean and will usually hear it ping. Just change it to level 2 as soon as you can until that tank is run out.
Old Sep 11, 2008 | 02:08 PM
fx4tough07's Avatar
ok thanks guys. dont ever plan on it happening, but you know how girls can be
Old Sep 11, 2008 | 02:30 PM
ThumperMX113's Avatar
She can't remember that it needs 93 octane? Will she forget she has a boyfriend at the bar, too?
... joking.
Old Sep 11, 2008 | 11:26 PM
JackandJanet's Avatar
Bluejay, are you sure about this? Why would the engine run "lean"? Yea, it should knock, especially under load, but the A/F mixture ratio will not be effected.
However, the effect, running "hot" and damage to the engine may be the same, and that may be what you were talking about.
- Jack
