Edge evoultion-help!!!
i have a 1999 f-150 4.6 V8 truck and i just programmed an edge evolution in it. i need help. if someone can, somehow i need to know tha best tuning for towing and tha best tuning for high performance because i dont know enough about tha engine and i dont wanna set things too high or too low. if somebody could help me out i would appreciate it greatly.
u have 3 pre programmed tunes right?
level 1- just shift firmness i believe
level 2- power and shift firmness (safe on 87 octane)
level 3- 93 octane performance and shift firmness
not 100% sure as i got rid of my edge after a couple weeks because i hated it. but it should say next to each level what it is.
Level 2 is the one you want to use for towing. Again, you can still "customize" it to an extent and change other things as discussed for level 1.
Level 3 is a performance tune. Use it IF you are using 91 octane gas AND NOT towing. Do not use this as a towing tune (unless you're pulling something very light).
It almost sounds like you don't have a manual. You can download one from here: http://www.edgeproducts.com/installa...structions.php It says it's installation instructions, but it's the user manual too.
When you really want to wake up your truck and have fun, talk to Bill Cohron at www.powerhungryperformance.com about trading in your Edge for a Gryphon and custom tunes, instead of the "canned" tunes you have.
Welcome to the forum!
- Jack
