2008 Limited with Tuner
Well the PCM inputs are controlled via the tune. 4x4 Low Switch and a Transfer case switch. 4x4 Low has a whole different driver demand table or what controls the pedal feel. The AWD Full-time t-case does not have 4x4 Low; but you can lock it into 4 High.
You're all probably putting this question to the wrong people. Ask the tuners!
If you have AWD, can they tune for it? My guess is, YES, but I certainly don't know for sure.
If it's part time 4WD, who cares? You're not going to have a tune that you load every time you slip it into 4WD.
So, call Bill at PHP, Justin at VMP, or Mike at TP and learn what you need to know.
- Jack
- Jack
Basically, there should be no difference, but I can verify if you send me your computer code.
- Jack
You got that right! (Although I like to fool myself into thinking I do at times). :o
- Jack
- Jack
