Edge Evolution or PHP Gryphon?
Old Jun 11, 2008 | 10:23 PM
GregFry's Avatar
I've been doing some research on these two programmers and they appear to be pretty much the same. Is there some reason I would want to consider one over the other? Is there any reason I couldn't start out with the evolution and then have it custom programmer by PHP? And if so, wouldn't that essentially make it the same as the Gryphon?
Old Jun 11, 2008 | 10:31 PM
weshova's Avatar
evolution 400 bucks
upgrade 25 bucks
custom tune 50 bucks
total 475 with only 1 tune
gryphon with 3 tunes 495 (i believe)
get the gryphon you'll be happy, the edge can no longer be programmed due to CARB certification
Old Jun 11, 2008 | 10:36 PM
hoss66's Avatar
the gryphon is an edge just re named with custom tunes. the gryphon is the better deal because they are about the same price.
Old Jun 12, 2008 | 12:11 AM
JackandJanet's Avatar
Weshova gave you the "straight talk" here. It's a no-brainer!
- Jack
Old Jun 12, 2008 | 12:50 AM
lil_man's Avatar
Originally Posted by weshova
evolution 400 bucks
upgrade 25 bucks
x2 or you can get a edge from ebay for cheaper and then send it to them!!!! i saw them on ebay for 250ish from some of the sellers.... Just a thought
Old Jun 12, 2008 | 02:33 AM
Fifty150's Avatar
Consider the alternative
SCT Livewire Tuning, Display & Datalogging Device for all 1996 & newer Ford Motor Company Vehicles!
This is the new device that has the industry in an uproar, winning SEMA's prestigious International New Product Award!
This unit comes pre-programmed with "canned" SCT files for most common Ford Motor Company vehicles, and even better, is also loaded up with your choice of 3 different Troyer Performance custom tunes!
Troyer Performance custom tuning, which is included in this unit, gives you even better power & performance gains and much better driveability than any other tuning, even on BONE STOCK vehicles!
Key Features:
• Pre-Loaded with Dyno Proven Tune Files
• Stores up to 3 Custom Tune Files
• Reads / Clears DTC Trouble Codes
• User Adjustable Features
• Monitor Popular External Sensors
• 2008 Models Supported
• Estimates HP, TQ, 1/4 Mile ET & 0-60mph
• High Speed Datalogging
• Built-In High Intensity Shift Light
User Adjustable Features:
• WOT Fuel Adjustment • Cooling Fan Temps • Fuel Injector Size
• Spark Adjustment • Rev / Speed Limiters • Air Intake Selection
• Axle Ratio • Idle RPM • Traction Control On / Off
• Tire Size - Rev / Mile • Transmission Shift Points • Two StepOn / Off RPM
* Not all adjustments available on all vehicles
Livewire Overview:
The SCT LIVEWIRE is NOT just another Flash Device. LIVEWIRE is the most ADVANCED Pre-Programmed & Custom Tunable Flash Device available on the market! Not only does LIVEWIRE arrive PRE-LOADED with Dyno Proven tune files specifically calibrated for your vehicle, it ALSO stores up to 3 Custom tune files! This allows you to retain the PRE-LOADED tune files and your factory uploaded tune file even after having your vehicle CUSTOM TUNED! LIVEWIRE also features high speed USB data logging of multiple OBD-II PCM parameters, a dedicated wideband air/fuel monitoring port, the ability to datalog an additional analog signal and real-time instrumentation.
Old Oct 20, 2009 | 08:40 AM
BaggedFX2's Avatar
Key Features:
Livewire Overview:
I have the Edge EVO and am thinking about getting it programed with the Gryphon custom tunes... anyone have any feedback on the SCT Livewire? I just want to know if anyone has tried a side by side comparison to detail how one program may outperform another... always nice to have options!
Old Oct 20, 2009 | 09:03 AM
cstanek's Avatar
I'd assume Fifty150 has compared it side-by-side to other programmers since he claimed it offers
Just sayin'...
Old Oct 20, 2009 | 10:59 AM
mblouir's Avatar
It's $60 per custom tune. Good analysis.
So for a new Edge upgraded to Gryphon you're looking at $605 for 3 custom tunes. I got 2 custom tunes with my recent upgrade. Wish I'd have gone with Gryphon to start with.
Old Oct 22, 2009 | 02:41 PM
Darknightmare's Avatar
Im in the market for a tuner. I was also debating which of these two to get. It sounds like I'll be getting the Gryphon. I checked their site and they do not off it for the '09 yet. Am I wrong? I didn't see it on their site.
Old Oct 22, 2009 | 02:44 PM
FX4SCrew05's Avatar
I 've had an Edge for over a year now, I have had an AEM intake sitting in my garage for 6 months, and I will be getting exhaust soon. I need some custom tunes.
From what I understand my Edge will be $25 to convert and $60 every custom tune up to 3?
What is the turn around time lately?
Thanks,
Geoff
Old Oct 22, 2009 | 02:48 PM
I had my Edge for about 30,000 miles, converted to custom tunes, Gryphon, and there is no comparison. I have now had the custom tunes for about 31,000 and if it died on me, I would be ordering another one. My 87 Performance tune is better than level 3 was with the Edge. Especially the shifting and downshifting.
Old Oct 22, 2009 | 04:02 PM
ab46501's Avatar
Thanks,
Geoff
It varies depending on their work load so you might just want to call them and ask. I had mine converted a couple months back and it took just over 4 weeks. Well worth the wait though!
Old Oct 22, 2009 | 06:32 PM
cstanek's Avatar
You're correct. However, it sounds like they're close to being able to offer the Gryphon for 09/10 models. Check out their forum for the most up-to-date info.
http://dygytalworld.ehost-services139.com/forums/
Old Oct 22, 2009 | 07:58 PM
i.ride.suzuki's Avatar
The SCT device offers SO much more than what the Edge/Gryphon can do for data-logging, but this isn't a requirement for some.
Bluejay, consider putting that information your your signature, you will develop carpal tunnel with the amount of times you have to retype it.
