Tuning problem or Mechanical problem?
Old Jun 2, 2008 | 03:31 PM
har250r's Avatar
This morning before work i loaded up my Troyer 87 performance tune for the first time and when i went to lunch i noticed the check engine light on. I checked the code and it is P2004 - Intake Runner Stuck Open.
Could this be something caused by the tune that can be fixed by loading another tune or returning to stock or is it an actual mechanical fault that will need to be fixed?
Anyone have any suggestions?
Old Jun 2, 2008 | 03:40 PM
STX4MX's Avatar
I would return it to stock and see if it goes away first.
Old Jun 2, 2008 | 03:48 PM
har250r's Avatar
i'll definitily try that for my drive home
Old Jun 2, 2008 | 05:14 PM
ThumperMX113's Avatar
Return it to stock but I'm thinking it's a mechanical problem. Who knows.
Old Jun 3, 2008 | 01:18 PM
har250r's Avatar
Stock tune did the same thing, looks like i will be dropping my truck off at the dealer (with the stock tune ofcourse). Good thing i purchased the extended warranty.
Old Jun 3, 2008 | 01:24 PM
I'm guessing the intake runner is the plate underneath the intake manifold, right? I'm assuming the plates are different than the Mustangs ... What I'm getting at is that it'd be a good mod to remove the butterflies and the motor ... Of course you'd need a tune for it, more so a dyno tune because I don't think many people have done it. I don't know why someone hasn't made a set of them for the trucks. The plates are available for the S197 Mustangs ...
Old Jun 3, 2008 | 03:21 PM
FX4 Matt's Avatar
Registered User
Theres a guy in here that did take his off I think he called it CMC plate delete
Old Jun 3, 2008 | 04:11 PM
I think you're thinking about assasinator who put the 5.4L in his Mustang or whatever.
Old Jun 3, 2008 | 05:51 PM
Huitt24's Avatar
unlike the mustangs the plates are built into the intake not a seperate bolt on piece like on the mustangs so it takes removing the plates and plastic welding the holes up. If not done correctly you can damage the intake.
Old Jun 3, 2008 | 10:07 PM
Gotcha. I was wondering why more people haven't done it. I do remember assasinator doing that though.
Old Jun 4, 2008 | 12:11 AM
mt_b8's Avatar
don't let them flash your pcm
