edge shift point ?
Old May 11, 2008 | 08:21 PM
bmxrider5x's Avatar
Question edge shift point ?
hi i have a 97 f150 5.4l and today i changed all 8 coils and plugs and the iac valve. so i went home to finish getting the shift points correct. when i go to change them i load the previous settings and adjust from there i set 1-2 at 5000 and 2-3 at 5000. after i program it and go run it 1-2 shifts about 4900 and 2-3 about 4700 maybe 4800. my rev limiter is at 5300. im just curious on why its shifting early and not later like it should. before i did my tune up i think i had the shifts at 1-2 4875 and 2-3 about the same and it shifted right around 5100 and 5000. any suggestions are help would be wonderful. thanks in advanced
Old May 11, 2008 | 10:19 PM
bmxrider5x's Avatar
anyone have any ideas
Old May 11, 2008 | 10:23 PM
crash_lucky13's Avatar
from what i was told, the tranny settings take a trip or to to fully adjust because of the "learning" transmissions...
listen, make sure your tire size and gear ratio are set correct, i know you said you did a restore but just for @%$$'s and giggle's try it...
if not, call bill in the morning
on the tranny learning, i don't think i ever experienced where it DIDN'T happen when i programmed it, but i do remember reading on here about the edge programming and these tranny's...
Old May 11, 2008 | 10:39 PM
bmxrider5x's Avatar
yea the thing is that i have a spring for speedo not electronic like newer models it says its not available so i cant set those. when i did the tune up i disconnected the battery with it on lvl 3 custom tune. but that shouldnt matter because i've done it before and no problem. where can i get bills #. thanks
Old May 12, 2008 | 02:58 AM
www.powerhungryperformance.com
they are on the boards too... you'll see both the mr and mrs on here. they are AWESOME people to work with.
Old May 12, 2008 | 08:58 PM
bmxrider5x's Avatar
thanks for the link. i'll have to call tomorrow its too late now, but i'll let ya know what it was for sure
Old May 14, 2008 | 09:32 PM
shadowscrew7's Avatar
the way i read it inthe forum was the tranny doesn't actually shift until 200-300 r.p.m. over that setting at w.o.t. i think it was in "let see your custom setting for your edge" thread.
