Tuning While Getting Gas
Old Apr 30, 2008 | 11:10 AM
CANES676400's Avatar
I was putting 87 octane in my truck yesterday and since i was running the 93 octane tune i decided to switch them while i waited for the tank to fill. bad idea. this caused my gas gauge needle to be stuck in the quarter tank position and after some fiddleing with the tuner i decided to return it to stock and disconnect the battery. im guessing it recalibrates everything when the battery is disconnected because the gauge went up to full. just a warning for you other guys.
Old Apr 30, 2008 | 12:06 PM
Shinesintx's Avatar
I have changed tunes while fueling...no problems for me
Old Apr 30, 2008 | 12:28 PM
jacobet's Avatar
I have also tunned while getting gas and never had this happen, but I have had it happen when the truck was stock. After I would fill up the gas gauge would just sit on empty till I turned the truck off and back on. Whats the deal with that?
Old Apr 30, 2008 | 12:33 PM
FX4 Matt's Avatar
Registered User
Mine will do it if I leave the key on while fueling up its not a big deal it will go back to reading it right after you park it for a little while.
Old Apr 30, 2008 | 12:42 PM
ThumperMX113's Avatar
Correct. This isn't really caused by the tuning aspect, just the fact that the key is on. All new vehicles will do it, at least Fords.
Old Apr 30, 2008 | 02:05 PM
i.ride.suzuki's Avatar
Turning the key, Off-On-Off three times should reset the fuel gauge.
Old Apr 30, 2008 | 02:17 PM
jacobet's Avatar
thanks for the tip! its just anoying to have just put 80 bucks in the tank and the fuel gauge still says E!!
Old Apr 30, 2008 | 05:37 PM
051fdrof's Avatar
Pretty soon it will read 1/2 and it will be RIGHT...
Old Apr 30, 2008 | 07:56 PM
JackandJanet's Avatar
Sorta like a broken clock that's right twice a day?
- Jack
Old Apr 30, 2008 | 08:09 PM
Screw-Me-05's Avatar
Hell your gettin off cheap i put in 93 @3.91 a gal yep $111.00 bucks
