Has anyone had any CHT problems?
Old Apr 25, 2008 | 09:53 AM
JackandJanet's Avatar
Originally Posted by F150FXOnline
Well on the way home yesterday my Engine light came on and its started running REAL rough. Didnt know if I was going to make it home. Like it was only running on 4 cyl. I checked the hoses again and this time the bottom hose seemed much warmer. I'll prpbably just reset my edge to stock to reset the PCM and it will clear the engine light and take it to ford in 3 more weeks. Id like to take it to autozone for kicks now while the light is on and see what code it gives but not sure if I should drive it. shrug
Thanks guys for all your help and input!!!!!!
You were probably running in "fail-safe" mode. And, it sounds like you were hot for real. If you had kept on driving it, it probably would have shut down.
I'm with Paralyzer on this, why not change the thermostat? They're pretty cheap. In the past, I've done this and being Scottish, saved the coolant in a clean container. Then, I just poured that coolant back in when I got everything hooked back up.
- Jack
