XCal 3 = Wrench Light (!)
What is the deal? I return to stock and the truck runs fine. But with the canned tunes (Waiting for custom from Troyer), the wrench light comes on and the truck won't run for ****. Any fixes? Thanks in advance.
So the stock is ok but the canned has a warning , do you have any mods like CAI or Exaust
You should be able to read the DTC code with the Xcal-3 to see what is wrong
I have the S&B intake and a 3" cat back. I read the DTC code, it comes up with the code P060, I can clear that (turns off engine light) but the wrench still doesn't go away.
Did you try updating the firmware on the unit before installing? The Xcal3s had some problems with firmware, you might of got one of the earlier units.
