Edge & Stock F-150
With that said if you order custom tunes from bill if you ask for 87 octane performance on level 1 all he can tune is shift points?
I ordered his 87 Perf tune and his 93 Perf tune. I had him move the Edge canned level 2 over to the number 1 position for a towing tune and his 87 Perf is now my level 2 and his 93 Perf is now my level 3. That was just how I wanted it.
NO NO NO ! I was speaking about Edge canned tunes. Level one is only a shift tune, level 2 is a tow tune and level 3 is a performance tune. Bill can put whatever tune you want in any of the 1, 2, 3, positions.
My understanding is that there is room for 4 tunes of which one must be your stock tune. So, room for only 3 other tunes. Frankly, I cannot see why you would ever want to go back to a canned tune, Bill's tunes are that much better. Maybe there is a way to save them on a disk, I do not know. Bill could answer that.
is there a way to look at all the info in the gryphon and like write it down?? that way u could write down the canned tune info, then load ur custom tunes?? i hope you can because that would make resaleability much better
Hope this helps!
You could write down and reset all the "canned tune" defaults that can be user adjusted. These are things like idle rpm, timing advance, WOT shift points, etc., but, unless I'm horribly mistaken, reverting to those later (after loading a custom tune) will not give you back your "canned tune". The custom tune does many things you have no control over. It reprograms the PCM to control the truck in ways that go beyond those user settings. I'm guessing here, but perhaps things like the fuel-air mixture ratio across the RPM curve or the actual dynamic spark advance curve. There are probably other things as well.
Now anyone, am I mistaken?
- Jack
- Jack
Last edited by JackandJanet; Apr 29, 2008 at 08:42 PM. Reason: Added guess on things adjusted in a custom tune
