Throttle delay
Old Feb 10, 2008 | 12:04 PM
wyosf's Avatar
Throttle delay
I have an 07 Supercrew and have been having problems with a delayed throttle response. It's most noticeable when I am merging onto the interstate. I approached the interstate from the on ramp. I am at approx 50 MPH with my foot off the accelerator pedal. As I get to the interstate I began pushing on the accelerator pedal and nothing happens. After approximately a second the truck downshifts and takes off. It's like a carbeurated engine with a faulty accelerator pump. I took it to the dealer yesterday and was told nothing could be done becuase it's an electronic delay. My question is, will a tuner (hypertech, superchips, Xcal3) resolve this problem?
Old Feb 10, 2008 | 12:06 PM
ThumperMX113's Avatar
Yes a tuner will fix that problem.
I believe the Xcal2s will work for the 2007 model year, but I'm not positive. If you're going to spend the money for a tuner, do it right. Get a custom tuned Xcal2 or Xcal3. I suggest checking out Justin at www.VMPTuning.com, he does great work and he'll get you your tune fast.
Old Feb 10, 2008 | 12:26 PM
jpdadeo's Avatar
My 04 had major throttle lag until I got custom tuning. It made a huge noticeable difference
My personally choice is Troyer Performance for custom tuning. I base this recommendation on product reliability and customer service; both have been excellent IMO since the get go in 04
Old Feb 10, 2008 | 04:28 PM
openclasspro#11's Avatar
x2 on troyer been using their tuning since'03- zero issues
Old Feb 10, 2008 | 05:00 PM
051fdrof's Avatar
You don't need a custom tune. Evolution will eliminate the throttle lag.
Old Feb 10, 2008 | 06:52 PM
06darkstone's Avatar
noticeable improvement with a custom tune
I went with Troyer
Old Feb 10, 2008 | 07:39 PM
gilsnuxs's Avatar
X2 on the Edge Unit
Old Feb 10, 2008 | 08:20 PM
khindal's Avatar
Look at the cost of the Edge vs Custom Tuning. You may want to know more about both before making your decision.
Kevin
Old Feb 10, 2008 | 09:02 PM
The cost difference now is barely anything, it's dumb not to go the custom tune route IMO.
Old Feb 10, 2008 | 09:11 PM
i think you forgot to mention vmp at the end of ure post
Old Feb 10, 2008 | 09:16 PM
So how is it any different me preaching about VMP than you preaching about Troyer?
Go pound sand.
Old Feb 10, 2008 | 09:20 PM
Edge is custom tunable as well. Plus you get cool gauges.
Old Feb 10, 2008 | 09:25 PM
Go pound sand.
just helpin ya with your loyalty thump
Old Feb 11, 2008 | 01:05 AM
TexEdition's Avatar
The thing that fixed my throttle response issue, prior to any tunes, was the 3" AF1 intake. Made a huge difference when merging or passing.
No programming needed for the 3" intake, though I've since installed TP's tunes and couldn't be any happier!!
I guarantee that if you order up the stage 1 (3.5" intake, exhuast, tunes) you'll be one happy camper.
The intake kit only takes a very few tools and is easy to install. The tunes are very simple to load once you read the directions. If you don't want to or can't install the cat-back yourself then just take it to a local shop to be installed.. probably like $50 or so to install the thing.
