can anyone help please. Xcali3 load error
hello i have a 2007 f150 5.4. i got my Xcali3 today and plugged it in to upload the preprogrammed tune. it went all the way to 100% and then said "ATTENTION: Unable to upload stock files". i contacted SCF and they said they dont know whats going on but they took my files off my cp and said they would get back to me. but i was just wonder if anyone else was having this problem, and figured out an answer, or has any suggestions. thanks
my firmware is 1.1.130 and SCT told me that was the most up to date version.
to load the tune i went to program vehicle, install tune, pre-programmed, turned key on, it realized it was the 5.4 f-150, then turned key off, and tried loaded the defult tune on there. i did not try to adjust any of the settings.
ok, now if i have to update to 1.1.150 i can get that off their site right? how exactly would i get that updated version onto the tuner
Originally Posted by 07SportTCOB
my firmwire is 1.1.130 and SCT told me that was the most up to date version.
I am assuming you have already in stalled the SCT x3/livewire firmware updater version 1.33.
Go here> http://www.sctflash.com/download.php
Select the second option. (X3 Ford Flash Device Firmware) It is version 1.1.126. That is the latest flash/ Firmware update. Also version 1.0.8 is the latest update for the preprogrammed tunes. The 1.33 you have is only the software to update the x3.
Ahhh crap the link does not bring you to where i wanted. Oh well go to http://www.sctflash.com/ select support, select downloads & Drivers, select x3 device and it will display the files for the X3.
maybe i.ride is right. i might need 1.15. that maybe the only version that works with the 07. sound logical?
I think i would call who ever you bought it from and then call SCT.
yea i ordered it from troyer i called them and they said they had no idea but they would look into it. so i called SCT and they took the files off of it and said they would get back to me...that was last thursday. i called today, no answer. so i guess ill just send it back to troyer or maybe SCT and get a new one. my luck...
thanks for all your help
I'm retarded. 1.15 is for the XCAL2, i must of read your post wrong.
Install the Livewire / X3 Updater Software 1.33
http://www.sctflash.com/software/Liv...pdater1_33.exe
And download and update these two files:
http://www.sctflash.com/software/XC3...PRODUCTION.LWU
http://www.sctflash.com/software/X3LWTR108UP.lfu
I also own a 2007 5.4 and I just had the same error above (just got the X3 today)
I've updated both firm ware and the Device Tune Revision to the most up to date versions directly from the SCT website.
Before I start making any phone calls. Has anyone found a correction? Specifically 07SportTCOB?
Thanks in advance.
Thanks in advance.
