Engine ping with the Edge
Originally Posted by openclasspro#11
anytime,if they are the originals-i'd soak a nite before and remember not to get any antiseize on the tips-hope it solves the problem-i know it did in mine
Originally Posted by Kevin24
Hey Phil, you were right. I changed the front 02's and the pinging went away completely
Thanks again for the advice
glad i could help and the issue went away-phil
Also Phil how do you like those underdrive pullies??? Thinking about getting a set myself.
Ya and my truck seems to have alot better throttle response now at almost any throttle position. Did you notice that too??
myself would change them-remember in closed loop the o2's adjust for the fuel, not the pcm- changed mine solved the issue- at that was with 28k miles-i bet they are getting buildup on the tips and are probably getting lazy-phil
Where are you getting the A/F from? The short and long fuel trims are not an accurate indication of actual A/F ratio.
I'm not trying to doubt you BTW, I just see a lot of shade tree engineering here on the forums with without any actual knowledge of how it really works. I'm just trying to help out if I can.
Dude I am by know means even saying anything bad about Troyer and his shop. They are top notch. I'm intrigued though as to how you ate a set of o2 sensors in 30k miles. I've seen premature failures on the o2's before but it is usually just one, or an issue in the wiring. The fuel system goes into OL and OL-Drive under hard acceleration and wide open throttle, which is using a predetermined fuel table. These are also the conditions at which pinging typically occurs.
Are you using the wideband setup they have on their website? I was interested in getting a wideband O2 for my ride after I put the cams in
