Troyer Tunes are here!
Originally Posted by kuhl0040
Another Minnesotan here, I got the X3 about a month ago and still awaiting the Troyer tunes, I got the same 87 tow, 87 perf, and 91 perf. I have used the 91 perf from SCT and I agree, the shifting from 1-2 is quite a bit different. I was worried it was because it is so damn cold here and was wondering if that affects the tuning at all. Maybe if Mike see's this he could respond for tuning for the cold *** weather up in MN?
Tyler
Tyler
This "harsh" shifting does kinda scare me though because I don't like it slammin in where it almost jolts you....I might have to call Mike and talk before they start w/ my tunes.
the harder you accelerate, the firmer it shifts. it doesnt *slam* its just real quick and efficient, *firm* is a better way to describe it. But on light acceleration, it shifts like stock.
to me its perfect. you want to go fast, it shifts fast. you want to go slow, it shifts nice and calm.
Originally Posted by Shinesintx
Ford cannot put these tunes on their trucks...they will not pass emissions...those of us with tunes need to return out trucks to stock before they will pass. Thumper (I think) said to drive it stock 30 minutes before getting inspected.
Kevin
in my last 2 vehicles over the past 5yrs with tp's tunes- mine passed with flying colors with 93 performance tune loaded-phil
On the harsh 1-2 shift; there is a difference between a nice quick, crisp, firm, yet SMOOTH shift and a quick, firm, harsh or "slammed" shift that can literally make the truck vibrate. I know what you are describing because I have experienced this to some degree with all tunes I've had (SCT, VMP and Troyer). The SCT and VMP tunes both slammed the 3-4 shift rather violently after intitally loading them so I turned the shift pressure down to -25 on that shift which helped right away and then after numerous drived cycles the problem went away and I was able to go back to 0 on the 3-4 shift pressure, the 1-2 and 2-3 did not do this. The TP tunes also intially would slam the 1-2 shift however not really that bad but I'm pretty **** about the truck being just right so I turned shift pressure down to -15 on that shift and it went away as well so I was able to bring it back to 0. This did not happen on the 2-3 or 3-4 shifts. I spoke with Mike about this when at his shop and we drove the truck after the dyno tune but it shifted perfectly (which I figured since it was already long gone). Perhaps it's something to do with the learning phase? This would usually happen when applying heavier throttle then backing off to some degree right before the shift. Either way it went away in all cases for me after some drive cycles.
Originally Posted by Rikidybones
I have the same situation, 1-2 shift 'slams' my truck forward and ive put on around 1,500 miles on it using the 87 perf tune...guess its suppose to do that.
Originally Posted by openclasspro#11
think before you type
Early Christmas Today
OK today was a good day-first off(little off topic) The local motorcycle dealer called today, the wire luggage rack i ordered was in-awsome
And then when I get home there was a little box from UPS
no warning-no email-no phone call-what the heck did I order-not expecting anything and then I read the box-return address was Troyer performance
Xcall 3 with custom tunes finally arrived-best part being I ordered the Xcall 2 (10-24-07) but then they came out with the X call 3, and apparently its better because thats the one they sent me
Anyways got the 87 performance tune loaded and ready to go-she is still trying to figure whats going on with the shift points but other than that shes good to go-its like a whole new truck
Tuner really woke this thing up-cant get the tires to spin though-tried standstill and tried running brakes-nothing, the LS axle doesnt let me do, just throws your a## in the seat and goes like hell
The unreliable seat in the pants dyno says it has alot more power-shifts better and overall is freakin awsome now
Just another happy camper with troyer tunes
Does anybody keep the tuner in the truck at all times in case its needed or do you guys keep it in the house? Just curious on that one
