Formula for Tire Size
So I had my Edge booklet but my smart girlfriend threw out the box for my Edge which also included my booklet. I have 306/65/18 BFG's if anyone knows it off by heart. Is it 3682mm? If not could someone post it!!
(Width x Aspect Ratio) x 2
(305 x .65) x 2 = 396.5 mm (this is total sidewall height)
Rim Diam. x mm per inch
18 x 25.4 = 457.2 mm (this is the diameter of the rim)
Sidewalls + Rim = Total Diameter
396.5 + 457.2 = 853.7 mm
Diameter x PI = Circumference
853.7 x 3.14159265 = 2682 mm
I have found that most tires will require what I call a "squish" factor to accurately correct for diameter change where the tire is squished from ground contact. This is usually about 3%.
2682 mm x .97 = 2602 mm
So for 305/65-18 tires, your should be at 2602 mm.
Take care.
Bill
Last edited by ASEMechanic; Dec 11, 2007 at 09:58 PM. Reason: Slight miscalculation due to a brain to keyboard error.
Thanks Bill!
LOL to be honest I suck at math and the first time I did that. I had to do the question like 6 times to get that answer.
http://www.powerhungryperformance.co....htm#utilities
Right-Click and select [Save As], save to your hard drive and then install.
Enjoy.
Bill
